Shark Ultimate Professional Power Cord Replacement
  1. Shark Ultimate Professional Power Cord Replacement, Power Cord: step 1, image 1 of 3 Shark Ultimate Professional Power Cord Replacement, Power Cord: step 1, image 2 of 3 Shark Ultimate Professional Power Cord Replacement, Power Cord: step 1, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the two 11.5mm screws on the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
    Ask FixBot
  2. Shark Ultimate Professional Power Cord Replacement: step 2, image 1 of 2 Shark Ultimate Professional Power Cord Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the two 11.8mm screws holding the white clamp to the iron.
    • Use the Phillips #0 screwdriver to remove the two 6.6mm screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
    Ask FixBot
  3. Shark Ultimate Professional Power Cord Replacement: step 3, image 1 of 3 Shark Ultimate Professional Power Cord Replacement: step 3, image 2 of 3 Shark Ultimate Professional Power Cord Replacement: step 3, image 3 of 3
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Pull the rubber stopper through the split end of the wire.
    • Pull the wire through the plastic cover.
    Ask FixBot
4 other people completed this guide.
Drew Carff
880 Reputation
5 Guides authored
6 Guide Comments
Where can you get a replacement power cord?
dnojokes - Reply Share
Yes, where can we get cords? I see a lot of people having trouble with shark irons
Betty Gulley - Reply Share
These instructions are not helpful at all without a source to purchase a replacement cable. Two people have previously asked this question. Can we get a response? I have done extensive searches online for a POLARIZED 16/2 HPN power cable with crimped ring terminals. NON-polarized ones are cheap and readily available. The show up immediately when searching for an iron replacement power cable. That’s not the cable used for this iron, nor is it the cable used in the pictures of this repair. Please tell us where we can purchase the cable, or even tell us you don’t know. Please, don’t just ignore the inquiry.
MDGadget - Reply Share
Model# GI505-55 uses security T-10 screw used to secure back panel. Suggest testing both conductors for continuity from above white clamp to the ring connectors. This may be the point of failure if the clamp was over-tightened. In this case, the cord can be reused with a loss of 6 inches and crimping of new ring connectors.
Andrew Shamis - Reply Share
Thank you Andrew!
Ferdinant - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 79
All Time: 10,264
