Shark Ultimate Professional Heat Plate Replacement
  1. Shark Ultimate Professional Heat Plate Replacement, Heat Plate: step 1, image 1 of 3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: step 1, image 2 of 3 Shark Ultimate Professional Heat Plate Replacement, Heat Plate: step 1, image 3 of 3
    • Remove the two screws at the back of the iron.
    • Remove the back cover piece.
    • Make sure iron is unplugged and cooled off.
    Ask FixBot
  2. Shark Ultimate Professional Heat Plate Replacement: step 2, image 1 of 2 Shark Ultimate Professional Heat Plate Replacement: step 2, image 2 of 2
    • Remove the two screws holding the white clamp to the iron.
    • Remove the two screws holding the black wires to the body of the iron.
    • Removing the left black wire will also free the red wire, attached by the same screw.
    Ask FixBot
  3. Shark Ultimate Professional Heat Plate Replacement: step 3, image 1 of 1
    • Pull the split end of the power cord upward through the ball joint of the iron.
    • Set aside power cord.
    Ask FixBot
  4. Shark Ultimate Professional Heat Plate Replacement: step 4, image 1 of 3 Shark Ultimate Professional Heat Plate Replacement: step 4, image 2 of 3 Shark Ultimate Professional Heat Plate Replacement: step 4, image 3 of 3
    • Remove remaining screws that hold a wire on the bottom (brown and blue).
    • Unscrew from left to right.
    • Unclip the black adapter piece on the bottom right.
    • Wires order (from left to right): Brown, Blue, Red, Black
    Ask FixBot
  5. Shark Ultimate Professional Heat Plate Replacement: step 5, image 1 of 2 Shark Ultimate Professional Heat Plate Replacement: step 5, image 2 of 2
    • Remove two screws (left and right) affixed to circuit board.
    Ask FixBot
3 other people completed this guide.
Drew Carff
880 Reputation
5 Guides authored
3 Guide Comments
This is an incomplete guide. Why even put it up. So silly and ridiculous. Not Good at all.
Muhammad Ahmad - Reply Share
incomplete guide
F1058 HARRISH RAJANDRAN - Reply Share
Where is the part about the heat plate?
Nealy Moxam - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 50
All Time: 3,219
