Introduction
Before you begin replacing the circuit board in your Shark Ultimate Professional iron, make sure the unit is unplugged and completely cooled down. Failing to do so can result in serious electric shock or burns.
This guide will walk you through every step needed to safely disassemble the iron, disconnect its wiring, remove the old circuit board, and install the replacement. Take care to follow each instruction. Skipping or rushing a step could damage components or create a safety hazard. Once completed, the reverse process will get your iron reassembled and ready for use.
Use the Philips head #0 screwdriver to remove the two 11.49mm screws at the back of the iron.
Remove the back cover piece.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
6 other people completed this guide.
4 Guide Comments
Where can u buy the circuit board professional 1800 version?
How much does the circuit board cost? and where can i purchase it?
