Shark Steam Pocket Mop Power Cable Replacement
    1. Shark Steam Pocket Mop Power Cable Replacement, Back Panel: step 1, image 1 of 3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: step 1, image 2 of 3 Shark Steam Pocket Mop Power Cable Replacement, Back Panel: step 1, image 3 of 3
      • Begin by removing the 8 quarter inch phillips head screws found along the back panel
      • Once all 8 screws have been removed, gently remove the back panel from the rest of the mop's body
      Ask FixBot
    1. Shark Steam Pocket Mop Power Cable Replacement, Power Cable: step 2, image 1 of 2 Shark Steam Pocket Mop Power Cable Replacement, Power Cable: step 2, image 2 of 2
      • Start by removing the two 1/8th inch Phillips head screws with your Phillips head screwdriver.
      • Gently remove the small plastic piece holding the wires against the plastic midframe of the mop.
      • Next use your wire cutters to remove the two plastic connectors and replace those wires with your new ones.
      Ask FixBot
Jacob Howe
549 Reputation
5 Guides authored
USF Tampa, Team S13-G7, Cagle Fall 2017 Member of USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 54
All Time: 2,376
