Shark Rotator NV502 Roller Brush Replacement
  1. Shark Rotator NV502 Roller Brush Replacement, Roller Brush: step 1, image 1 of 2 Shark Rotator NV502 Roller Brush Replacement, Roller Brush: step 1, image 2 of 2
    • Pull the handle while pressing the lift away button to remove the body of the vacuum.
    Ask FixBot
  2. Shark Rotator NV502 Roller Brush Replacement: step 2, image 1 of 2 Shark Rotator NV502 Roller Brush Replacement: step 2, image 2 of 2
    • Flip the base of the vacuum over to access the bottom.
    • Remove the two small wheels with a metal spudger.
    Ask FixBot
  3. Shark Rotator NV502 Roller Brush Replacement: step 3, image 1 of 2 Shark Rotator NV502 Roller Brush Replacement: step 3, image 2 of 2
    • Remove the nine 16 mm screws using the Phillips #2 Screwdriver. Press on the side tabs in the middle of the panel and pull up to reveal the screw under the hose connection.
    • Remove the two 13.5 mm screws using the Phillips #2 Screwdriver.
    Ask FixBot
  4. Shark Rotator NV502 Roller Brush Replacement: step 4, image 1 of 2 Shark Rotator NV502 Roller Brush Replacement: step 4, image 2 of 2
    • Pull up on the cover and move it to the side.
    • Remove the wire attached to the base by squeezing the pin and pulling up.
    Ask FixBot
  5. Shark Rotator NV502 Roller Brush Replacement: step 5, image 1 of 2 Shark Rotator NV502 Roller Brush Replacement: step 5, image 2 of 2
    • Remove the two 11 mm screws using the Phillips #2 screwdriver.
    • Lift the roller brush cover up.
    Ask FixBot
  6. Shark Rotator NV502 Roller Brush Replacement: step 6, image 1 of 1
    • Pull out the roller brush.
    Ask FixBot
5 other people completed this guide.
Samuel
338 Reputation
3 Guides authored
Cal Poly, Team 4-3, Livingston Fall 2016 Member of Cal Poly, Team 4-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G3
4 Members
19 Guides authored
7 Guide Comments
Good day, I have a rotator lift away NV500 my belt indicator light stopped working but I was still getting suction. I replaced the filters and hep filters,as well as changed the belt. I cleaned off the dust and then carefully put the vacuum back to gather. I went to plug it in all worked until I pushed the roller brush indicator on and it still did not work. What else could it be? Any suggestions.
I await your reply
Angela
Angela Cox - Reply Share
I have the same issue…brush roller will not work.
csweetccr - Reply Share
Same here what would be wrong with it
Johnnie Twyman - Reply Share
Great instructions - the 11mm hidden screws plus one more were tricky to find. Thanks so much for the great graphics and very clear disassembly steps; I almost gave up and was going to take it to a dealer for a costly repair fee. Thanks again!
Mathew Curran - Reply Share
Great directions and guidance - many thanks!
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 102
All Time: 29,225
