Shark Rocket Zero-M Belt Replacement
    1. Shark Rocket Zero-M Belt Replacement, Belt: step 1, image 1 of 1
      • Flip the vacuum on its right side.
      Ask FixBot
    2. Shark Rocket Zero-M Belt Replacement: step 2, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 2, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 2, image 3 of 3
      • Turn the T10 Security Bit screwdriver counterclockwise to remove the 15mm screw.
      Ask FixBot
    3. Shark Rocket Zero-M Belt Replacement: step 3, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 3, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 3, image 3 of 3
      • Turn the vacuum face down.
      Ask FixBot
    4. Shark Rocket Zero-M Belt Replacement: step 4, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 4, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 4, image 3 of 3
      • Use a spudger to pry the side of the vacuum open.
      Ask FixBot
    5. Shark Rocket Zero-M Belt Replacement: step 5, image 1 of 3 Shark Rocket Zero-M Belt Replacement: step 5, image 2 of 3 Shark Rocket Zero-M Belt Replacement: step 5, image 3 of 3
      • Use a spudger to pry the old belt away from the two gears.
      • The new belt will be tight and difficult to put back on. In order to reinstall, place the belt on the brushroll, then rotate the brushroll a couple rotations to make sure the belt is aligned correctly.
      Ask FixBot
    6. Shark Rocket Zero-M Belt Replacement: step 6, image 1 of 1
      • Repeat on the other side of the vacuum.
      Ask FixBot
Nadia Martinez
133 Reputation
1 Guide authored
1 Guide Comment
What is the belt part number looking but can not fine.
Help would be greatly appreciated thank you
jason kennedy - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 42
All Time: 4,314
