Shark Rocket Professional Hose Replacement
    1. Shark Rocket Professional Hose Replacement, Main Hose: step 1, image 1 of 3 Shark Rocket Professional Hose Replacement, Main Hose: step 1, image 2 of 3 Shark Rocket Professional Hose Replacement, Main Hose: step 1, image 3 of 3
      • Look at the Shark Rocket Professional's Extension Rod.
      • Identify where the hose connects to the main body of the vacuum.
      • Press the tabs on the sides of the connector to remove the hose.
      • You can use a long, thin object to unclog the hose.
      • If this fixes your problem, then you are finished with this guide.
      Ask FixBot
    2. Shark Rocket Professional Hose Replacement: step 2, image 1 of 2 Shark Rocket Professional Hose Replacement: step 2, image 2 of 2
      • Look at the vacuum handle and locate the orange button that says "Handle" with a picture of a lock.
      • Press the button and remove the handle.
      Ask FixBot
    3. Shark Rocket Professional Hose Replacement: step 3, image 1 of 2 Shark Rocket Professional Hose Replacement: step 3, image 2 of 2
      • Look at the vacuum handle.
      • Using a T-15 screwdriver, remove the five 15mm screws in the handle by turning them counter-clockwise.
      Ask FixBot
    4. Shark Rocket Professional Hose Replacement: step 4, image 1 of 3 Shark Rocket Professional Hose Replacement: step 4, image 2 of 3 Shark Rocket Professional Hose Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to pry open the handle.
      • Don't worry if the handle sounds like it is going to break; it takes a lot of force to pull apart.
      • When popping open your handle, the small grey piece of plastic(pictured in the last frame) will fly out.
      Ask FixBot
    5. Shark Rocket Professional Hose Replacement: step 5, image 1 of 3 Shark Rocket Professional Hose Replacement: step 5, image 2 of 3 Shark Rocket Professional Hose Replacement: step 5, image 3 of 3
      • The orange plastic piece may have naturally fallen out at this point.
      • Look a your handle.
      • Using your hands, pull the tube from the nozzle of the handle.
      • The tube is soldered onto a wire connecting to the plastic orange piece inside the handle.
      • Cut this connection with wire clippers to remove and replace your tube.
      Ask FixBot
2 other people completed this guide.
Brad Iglesia
316 Reputation
2 Guides authored
Cal Poly, Team S18-G6, Livingston Winter 2018 Member of Cal Poly, Team S18-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G6
4 Members
60 Guides authored
4 Guide Comments
How about an expla8nation about how t9 actually do the lower the hose inside the brush head
Jonathan Hill - Reply Share
How do you replace the hose in the beater head
daveve2 - Reply Share
Thank you for this, this guide helped a ton.
Bradlee Johnson - Reply Share
How long does it take to answer acquestion?
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 43
All Time: 6,997
