Shark Rocket Powerhead AH401 Panel Screws Replacement
    1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: step 1, image 1 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: step 1, image 2 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Brushroll: step 1, image 3 of 3
      • Ensure the device is turned off and unplugged from any power source before beginning work.
      • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
      • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
      • Lift the brushroll cover upward.
      Ask FixBot
    2. Shark Rocket Powerhead AH401 Panel Screws Replacement: step 2, image 1 of 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: step 2, image 2 of 2
      • Lift the brushroll out by pulling the tab labeled "pull".
      Ask FixBot
    1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: step 3, image 1 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: step 3, image 2 of 3 Shark Rocket Powerhead AH401 Panel Screws Replacement, Dust Cup: step 3, image 3 of 3
      • Push down on the dust can lever to release the dust can in order to get to the filter grill.
      Ask FixBot
    2. Shark Rocket Powerhead AH401 Panel Screws Replacement: step 4, image 1 of 2 Shark Rocket Powerhead AH401 Panel Screws Replacement: step 4, image 2 of 2
      • Remove the dust cup by lifting it off the dock.
      Ask FixBot
    1. Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: step 5, image 1 of 2 Shark Rocket Powerhead AH401 Panel Screws Replacement, Back Panel Screws: step 5, image 2 of 2
      • Flip the device over so that the bottom is face up.
      • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
      • Two 14 mm Torx screws
      • Two 16 mm Torx screws
      • Four 21 mm Torx screws
      Ask FixBot
Toan Pham
269 Reputation
3 Guides authored
Cal Poly, Team S19-G3, Livingston Winter 2018 Member of Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 83
All Time: 1,488
