Up to 20% off select tools
Shark Rocket IX141 Wheel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
42
Past 30 Days:
152
All Time:
1,202
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your Shark Rocket IX141 not gliding properly along surfaces (having tottery or janky movement), getting stuck, or not moving at all? If so, the wheels may have to be replaced. Without working wheels, your Shark Rocket IX141 will fail at its most basic functions, since the wheels are what allow movement.
Though taking off the wheels may appear daunting, following this guide will allow you to replace your Shark Rocket IX141's wheels quickly and efficiently.
    1. Shark Rocket IX141 Wheel Replacement, Floor Nozzle: step 1, image 1 of 2 Shark Rocket IX141 Wheel Replacement, Floor Nozzle: step 1, image 2 of 2
      • Press the indigo button and pull the vacuum stick away from the floor nozzle.
      Ask FixBot
    1. Shark Rocket IX141 Wheel Replacement, Wheel: step 2, image 1 of 1
      • Flip the floor nozzle so the bottom part is facing up.
      • Use a TR10 Torx Security screwdriver to remove the two 20 mm screws.
      Ask FixBot
    2. Shark Rocket IX141 Wheel Replacement: step 3, image 1 of 2 Shark Rocket IX141 Wheel Replacement: step 3, image 2 of 2
      • Grab the wheel, digging your fingers behind it for the best grip.
      • It will require some strength, but you'll be able to pop the wheel off from here.
      Ask FixBot
Author
with
Stevie Lytle
603 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 152
All Time: 1,202
