Shark Rocket HV301 Rotary Brush Replacement
    1. Shark Rocket HV301 Rotary Brush Replacement, Rotary Brush: step 1, image 1 of 3 Shark Rocket HV301 Rotary Brush Replacement, Rotary Brush: step 1, image 2 of 3 Shark Rocket HV301 Rotary Brush Replacement, Rotary Brush: step 1, image 3 of 3
      • Flip the vacuum so the bottom base is visible.
      • Gently pry the bottom two wheels off with a plastic opening tool.
      Ask FixBot
    2. Shark Rocket HV301 Rotary Brush Replacement: step 2, image 1 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 2, image 2 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 2, image 3 of 3
      • Remove five visible screws with a Phillips #2 screwdriver.
      • Locate and twist the three plastic screws to the unlock position with a quarter or flathead screwdriver.
      Ask FixBot
    3. Shark Rocket HV301 Rotary Brush Replacement: step 3, image 1 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 3, image 2 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 3, image 3 of 3
      • Remove plate covering the roller brush.
      Ask FixBot
    4. Shark Rocket HV301 Rotary Brush Replacement: step 4, image 1 of 2 Shark Rocket HV301 Rotary Brush Replacement: step 4, image 2 of 2
      • Use a Phillips #2 screwdriver to extract the three screws revealed from removing the plate.
      Ask FixBot
    5. Shark Rocket HV301 Rotary Brush Replacement: step 5, image 1 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 5, image 2 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 5, image 3 of 3
      • Turn the vacuum over so the rotary brush is on the ground.
      • Grab the vacuum on both sides of the hose and pull up to remove the top of the vacuum halfway.
      Ask FixBot
    6. Shark Rocket HV301 Rotary Brush Replacement: step 6, image 1 of 2 Shark Rocket HV301 Rotary Brush Replacement: step 6, image 2 of 2
      • Gently pinch the head of the cable and pull upwards until the casing disconnects from the vacuum.
      • Proceed with removing the upper casing.
      Ask FixBot
    7. Shark Rocket HV301 Rotary Brush Replacement: step 7, image 1 of 2 Shark Rocket HV301 Rotary Brush Replacement: step 7, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the four visible screws securing the rotary brush to the vacuum.
      Ask FixBot
    8. Shark Rocket HV301 Rotary Brush Replacement: step 8, image 1 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 8, image 2 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 8, image 3 of 3
      • Remove the rotary belt on right side of vacuum from the bearing.
      • Gently lift the casing to remove the belt and brush from the vacuum.
      Ask FixBot
    9. Shark Rocket HV301 Rotary Brush Replacement: step 9, image 1 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 9, image 2 of 3 Shark Rocket HV301 Rotary Brush Replacement: step 9, image 3 of 3
      • Gently pry off the plastic casing on both sides of rotary brush.
      • Lift the clear plastic shell from the rotary brush.
      Ask FixBot
    10. Shark Rocket HV301 Rotary Brush Replacement: step 10, image 1 of 1
      • Remove the rotary belt attached to the brush and replace it if needed.
      Ask FixBot
24 other people completed this guide.
Jonathan Baruch
862 Reputation
1 Guide authored
Cal Poly, Team 10-5, Livingston Fall 2016 Member of Cal Poly, Team 10-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G5
4 Members
60 Guides authored
32 Guide Comments
This is a well written and very informative tutorial. Thank you for your time and effort. However, I am finding it difficult to locate a new rotary brush for my Shark Rocket model HV301. At best, I’ve been told that the rotary brushes available ‘May fit’ my vacuum. Hardly a resounding voice of confidence when ordering a replacement part. Does anyone know the part number or ordering information regarding the Shark Rocket model HV301 rotary brush? Thank you for your time.
TCP - Reply Share
I also need a new brush did you find out where to get one and could you pass it on to me thank you
Jeffro - Reply Share
Hi, I'm also having a hard time trying to find the rotary brush roll, does anyone have any suggestions where I can find & purchase it?
Rosalina Padilla - Reply Share
Try Amazon.com there are several parts for shark vacuum, just make sure to have the model number in hand. I hope this help.
Thanks!
Andres B - Reply Share
I want to give this author 30 points only because that seems to be the maximum. Excellent work; thank you very much.
Larry - Reply Share
Past 24 Hours: 20
Past 7 Days: 124
Past 30 Days: 683
All Time: 78,446
