Introduction
The internal filter on the Shark RV912 EZ helps protect the motor by trapping fine dust inside the airflow chamber. When the filter becomes clogged or worn out, the robot may lose suction, overheat, or leave debris behind. This guide will show you how to open the robot and replace the internal filter.
Turn off the robot and remove it from the charging dock. Flip the robot over and place it on a clean, flat surface.
