Shark Pet Perfect II Front Belt Replacement
    1. Shark Pet Perfect II Front Belt Replacement, Front Belt: step 1, image 1 of 1
      • Remove the motorized brush from the dust cup by pulling it apart.
      Ask FixBot
    2. Shark Pet Perfect II Front Belt Replacement: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the five 14mm screws from the face of the motorized brush.
      Ask FixBot
    3. Shark Pet Perfect II Front Belt Replacement: step 3, image 1 of 2 Shark Pet Perfect II Front Belt Replacement: step 3, image 2 of 2
      • Separate the motorized brush face plate by using a flat prying tool.
      Ask FixBot
    4. Shark Pet Perfect II Front Belt Replacement: step 4, image 1 of 3 Shark Pet Perfect II Front Belt Replacement: step 4, image 2 of 3 Shark Pet Perfect II Front Belt Replacement: step 4, image 3 of 3
      • Remove the brush roller by lifting vertically away from the brush head. It should come out easily along with the belt.
      • Be careful in handling the belt. If stretched or damaged, the belt can cause the motorized brush to operate incorrectly.
      Ask FixBot
Attached Documents
Tanner Brown
477 Reputation
3 Guides authored
UW Tacoma, Team S1-G5, Liner Summer 2017 Member of UW Tacoma, Team S1-G5, Liner Summer 2017
UWT-LINER-SU17S1G5
4 Members
48 Guides authored
1 Guide Comment
Thank you for this! I needed the picture to put it back together after I cleaned it out because it was not spinning. Working perfectly now! I also have an extra new battery if anyone needs it. :)
Aaron Woods - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 1,187
