Shark Navigator Roller Brush Compartment Replacement
    1. Shark Navigator Roller Brush Compartment Replacement, Roller Brush Compartment: step 1, image 1 of 1
      • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
      Ask FixBot
    2. Shark Navigator Roller Brush Compartment Replacement: step 2, image 1 of 2 Shark Navigator Roller Brush Compartment Replacement: step 2, image 2 of 2
      • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
      • The screws have varying lengths, so keep track of where each one goes for reassembly.
      Ask FixBot
    3. Shark Navigator Roller Brush Compartment Replacement: step 3, image 1 of 1
      • Remove the white plastic cover to expose the roller compartment underneath.
      Ask FixBot
19 other people completed this guide.
Jeremiah Shyne
1,403 Reputation
2 Guides authored
17 Guide Comments
Tried driver tips on two MULTI-TIP tools (standard & metric), but none fit. Looks like a very small 6-sided star w/a hole n middle. Trying again tomorrow w/mini metric set. I agree, 10 screws, two under wheels is way too much trouble for something you need quick access to often for brush cleaning. The hose has several places where it comes apart very easily. I was impressed, but this roller plate ruined it.
Bettie Howard - Reply Share
Nice guide very easy to follow took awhile to complete only because vacuum parts I took off with very dirty had to clean other than that the guide was very very useful and very very easy to follow appreciate it!!!
Kenneth Johnson - Reply Share
Easy to get off but hard to get it bqck on. I put the name of my shark and took it apart and it was for a lift away which I dont have now I can’t get it back together HELP
Gail Jezik - Reply Share
Where did you find the replacement brush bar? Im having a heard time locating one.
meghmrr - Reply Share
This truly is not intended for the user to replace the roller, but rather, they would like you to pay a lot more to take it in to service! To have a star screw with hole - which is what mine has - not Philips - and under wheels and 10 of them of varying length, and good luck, like Bettie Howard said, getting the driver to fit into the deeper holes! I have no adapter or extension - means you’d have to purchase a special tool. Luckily for me, I didn’t have to replace the roller, but rather sucked a USB cable which quickly wrapped around it. I was trying to salvage it, but after 2.5 screws later, decided it was better to cut the cable!
a_1_jensen - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 96
All Time: 88,423
