Up to 20% off select tools
Shark Navigator Motor Replacement
Views: 19K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
133
All Time:
18,963
Comments: 26
20 comments on steps, 6 guide comments.
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Shark Navigator Motor Replacement, Roller Brush Compartment: step 1, image 1 of 1
      • Pop out the two small wheels located on the front end of the bottom of the roller brush compartment.
      Ask FixBot
    2. Shark Navigator Motor Replacement: step 2, image 1 of 2 Shark Navigator Motor Replacement: step 2, image 2 of 2
      • Remove the 10 Phillips screws located on the bottom of the roller brush compartment. (Two of these screws are located under the wheels from the previous step.)
      • The screws have varying lengths, so keep track of where each one goes for reassembly.
      Ask FixBot
    3. Shark Navigator Motor Replacement: step 3, image 1 of 1
      • Remove the white plastic cover to expose the roller compartment underneath.
      Ask FixBot
    1. Shark Navigator Motor Replacement, Motor: step 4, image 1 of 1
      • Once the vacuum top is opened, you can simply remove the motor as shown in the image.
      • Make sure to untangle or unhook any wires that are connected to the motor.
      • Once this is done, you can replace the old motor with a new one.
      Ask FixBot
Author
with
Molina Oung
289 Reputation
1 Guide authored
6 Guide Comments
Hi Where could I get a replacement motor from for NV501 model shark rotator .Or have the same motor rebuilt...Any help would be appreciated thank you.....
jacob - Reply Share
The screws on the bottom of roller brush compartment ARE NOT phillips head!!!!!!!!!!!!!!!!!!!!
randy - Reply Share
The screws are Phillips on mine. It may be a case of availability. If the manufacturer found a better deal on a different style of screw, they may have changed it.
Joe Evans - Reply Share
Mine has the security Torx screws. Those are the Torx bits with a round hole in the center. Anyway, what is the model number of the motor? I need a replacement motor, and am finding several in eBay but don't know which one is correct.
Roger - Reply Share
Have no suction but the roller still spins can it still be the Motor ?
Thompson Mick - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 133
All Time: 18,963
