Shark Navigator HEPA Filter Replacement
    1. Shark Navigator HEPA Filter Replacement, HEPA Filter: step 1, image 1 of 1
      • On the front of the vacuum, locate the latch on the bottom of the front vent.
      Ask FixBot
    2. Shark Navigator HEPA Filter Replacement: step 2, image 1 of 1
      • Press up on the latch and remove the front vent
      Ask FixBot
    3. Shark Navigator HEPA Filter Replacement: step 3, image 1 of 1
      • Lift the HEPA filter out of the vacuum
      Ask FixBot
3 other people completed this guide.
Heather Shanks
274 Reputation
1 Guide authored
4 Guide Comments
the taking out worked great but putting the new one back in is impossible.......will not fit i will not buy a new vac because of this........
lillian kresge - Reply Share
this is the second filter that i have purchased and it is the same...does not fit properly i could use a hammer to it?????
I can’t get the Hepa filter to come out, the front comes out easily, but the actual filter behind it will not. How do I remove it?
Lynn Davidson - Reply Share
@lynndavidson lay the machine on its back, get someone without fingernails to grab both sides of HEPA and pull STRAIGHT UP. It is pretty tight. You might be able to pop a side up by prying with a flat screw driver or small putty knife? Just don’t chip the housing.
K Jones - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 97
All Time: 13,572
