Shark NV352 Roller Brush Replacement
    1. Shark NV352 Roller Brush Replacement, Roller Brush: step 1, image 1 of 2 Shark NV352 Roller Brush Replacement, Roller Brush: step 1, image 2 of 2
      • Lift the latches on both sides of the vacuum to release the dust canister.
      • Remove the dust canister from the vacuum by lifting it up.
      Ask FixBot
    2. Shark NV352 Roller Brush Replacement: step 2, image 1 of 1
      • Lay down the vacuum to access the bottom panel of the roller brush compartment.
      Ask FixBot
    3. Shark NV352 Roller Brush Replacement: step 3, image 1 of 2 Shark NV352 Roller Brush Replacement: step 3, image 2 of 2
      • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
      Ask FixBot
    4. Shark NV352 Roller Brush Replacement: step 4, image 1 of 2 Shark NV352 Roller Brush Replacement: step 4, image 2 of 2
      • Remove the eight 19mm Phillips #2 screws from the plastic cover.
      • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
      Ask FixBot
    5. Shark NV352 Roller Brush Replacement: step 5, image 1 of 2 Shark NV352 Roller Brush Replacement: step 5, image 2 of 2
      • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
      • Remove the wheels by pulling them out of their axles, away from the vacuum.
      Ask FixBot
    6. Shark NV352 Roller Brush Replacement: step 6, image 1 of 2 Shark NV352 Roller Brush Replacement: step 6, image 2 of 2
      • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
      • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
      Ask FixBot
    7. Shark NV352 Roller Brush Replacement: step 7, image 1 of 1
      • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
      Ask FixBot
    8. Shark NV352 Roller Brush Replacement: step 8, image 1 of 1
      • Take out the roller brush by lifting it out of its tray.
      Ask FixBot
9 other people completed this guide.
Amy Moran
621 Reputation
2 Guides authored
Cal Poly, Team S18-G5, Forte Fall 2017 Member of Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Members
60 Guides authored
1 Guide Comment
FOR SOME MODELS - THE BRUSH WILL NOT OPERATE IN AN UPRIGHT POSITION.
Shark navigator 350-353 series - if you have cleaned the roller and it doesn't work, TILT THE HANDLE BACK then try.
elaina heinz - Reply Share
Past 24 Hours: 3
Past 7 Days: 41
Past 30 Days: 110
All Time: 6,752
