Up to 20% off select tools
Shark NV352 Filter Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
25
Past 30 Days:
122
All Time:
1,851
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Dirty filters will cause the vacuum to work less efficiently. Make sure to replace your filter on a regular basis.
    1. Shark NV352 Filter Replacement, Filter: step 1, image 1 of 1
      • Ensure that you are removing the filters from the vacuum in an area that you don't mind getting dirty because the filters will be very dusty.
      • Lift the latches on both sides of the vacuum to release the dust canister.
      Ask FixBot
    2. Shark NV352 Filter Replacement: step 2, image 1 of 2 Shark NV352 Filter Replacement: step 2, image 2 of 2
      • Tilt the dust canister forward to release it from its position.
      • Carefully lift away the dust canister and set it aside.
      Ask FixBot
    3. Shark NV352 Filter Replacement: step 3, image 1 of 3 Shark NV352 Filter Replacement: step 3, image 2 of 3 Shark NV352 Filter Replacement: step 3, image 3 of 3
      • Remove the upper filter by lifting upwards on it.
      • Now that the lower filter is exposed, remove it by pulling it upwards.
      Ask FixBot
5 other people completed this guide.
Author
with
Vincent Leuzze
309 Reputation
1 Guide authored
Cal Poly, Team S18-G5, Forte Fall 2017 Member of Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 122
All Time: 1,851
