Shark Matrix RV2310 Wheel Assembly Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
23
Past 30 Days:
110
All Time:
1,457
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the wheel assembly for the Shark Matrix RV2310. This replacement may be used to address mobility issues in the vacuum. It is a fairly easy replacement, though it is important to ensure the battery is removed first so that the vacuum is off during this process.
Tools
    1. Shark Matrix RV2310 Wheel Assembly Replacement, Battery: step 1, image 1 of 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: step 1, image 2 of 3 Shark Matrix RV2310 Wheel Assembly Replacement, Battery: step 1, image 3 of 3
      • Remove the two 11 mm Phillips screws holding the battery plate in place.
      • Remove the battery plate.
      Ask FixBot
    2. Shark Matrix RV2310 Wheel Assembly Replacement: step 2, image 1 of 3 Shark Matrix RV2310 Wheel Assembly Replacement: step 2, image 2 of 3 Shark Matrix RV2310 Wheel Assembly Replacement: step 2, image 3 of 3
      • Remove the battery from the compartment.
      • Disconnect the electrical cable connection from the battery to the robot.
      Ask FixBot
    1. Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: step 3, image 1 of 2 Shark Matrix RV2310 Wheel Assembly Replacement, Wheel Assembly: step 3, image 2 of 2
      • Remove the five 11 mm Phillips screws holding the wheel assembly in place.
      • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
      Ask FixBot
    2. Shark Matrix RV2310 Wheel Assembly Replacement: step 4, image 1 of 1
      • Lift the wheel assembly out of the vacuum.
      • Do not pull or tug too hard on the wheel when lifting it, as there is a wire connection between the wheel and the motherboard.
      Ask FixBot
    3. Shark Matrix RV2310 Wheel Assembly Replacement: step 5, image 1 of 1
      • Undo the wire connection between the motherboard and the wheel assembly by gently pulling the wire out from the wheel assembly's connector.
      Ask FixBot
2 other people completed this guide.
Joshua Correia
715 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 110
All Time: 1,457
