Shark Matrix RV2310 Brushroll Replacement
  1. Shark Matrix RV2310 Brushroll Replacement, Battery: step 1, image 1 of 3 Shark Matrix RV2310 Brushroll Replacement, Battery: step 1, image 2 of 3 Shark Matrix RV2310 Brushroll Replacement, Battery: step 1, image 3 of 3
    • Remove the two 11 mm Phillips screws holding the battery plate in place.
    • Remove the battery plate.
    Ask FixBot
  2. Shark Matrix RV2310 Brushroll Replacement: step 2, image 1 of 3 Shark Matrix RV2310 Brushroll Replacement: step 2, image 2 of 3 Shark Matrix RV2310 Brushroll Replacement: step 2, image 3 of 3
    • Remove the battery from the compartment.
    • Disconnect the electrical cable connection from the battery to the robot.
    Ask FixBot
  3. Shark Matrix RV2310 Brushroll Replacement, Brushroll: step 3, image 1 of 2 Shark Matrix RV2310 Brushroll Replacement, Brushroll: step 3, image 2 of 2
    • Remove the three 8 mm Phillips screws from the plastic plate holding the brushroll in.
    • Make sure the device's battery has been fully removed from the device before proceeding. Failure to do so could potentially result in minor/moderate injuries.
    Ask FixBot
  4. Shark Matrix RV2310 Brushroll Replacement: step 4, image 1 of 3 Shark Matrix RV2310 Brushroll Replacement: step 4, image 2 of 3 Shark Matrix RV2310 Brushroll Replacement: step 4, image 3 of 3
    • Press in the two tabs on the side of the plate and pull upward to remove it.
    Ask FixBot
  5. Shark Matrix RV2310 Brushroll Replacement: step 5, image 1 of 3 Shark Matrix RV2310 Brushroll Replacement: step 5, image 2 of 3 Shark Matrix RV2310 Brushroll Replacement: step 5, image 3 of 3
    • Pull up on the darker orange side of the brushroll to remove it.
    Ask FixBot
Joshua Correia
679 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 64
All Time: 630
