Shark ION Robot S87 Drive Wheel Replacement
    1. Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: step 1, image 1 of 2 Shark ION Robot S87 Drive Wheel Replacement, Drive Wheel: step 1, image 2 of 2
      • Make sure device is turned off before attempting this replacement.
      • Remove three 13mm screws using a T15 Torx screwdriver.
      • Remove one 15mm screw using a Phillips #1 screwdriver.
      • Remove one final 15mm Phillips #1 screw.
      Ask FixBot
    2. Shark ION Robot S87 Drive Wheel Replacement: step 2, image 1 of 1
      • Carefully lift the wheel assembly out of the housing, making sure not to damage its connecting wire.
      Ask FixBot
    3. Shark ION Robot S87 Drive Wheel Replacement: step 3, image 1 of 1
      • Disconnect the wire carefully from the wheel assembly by pinching and pulling away from it.
      Ask FixBot
Trevor Davies
297 Reputation
2 Guides authored
2 Guide Comments
Dude you made my day. Cost me 14 bucks for a torx set and fixed my little cleaning buddy. All it needed was to be blown out with compressed air and plugged back in. THANK YOU!!!
DovieAndiSeTova - Reply Share
Where can we get the replacement wheel and motor?
Shelly G Petty - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 35
All Time: 2,693
