Shark ION Robot S87 Battery Replacement
    1. Shark ION Robot S87 Battery Replacement, Battery: step 1, image 1 of 3 Shark ION Robot S87 Battery Replacement, Battery: step 1, image 2 of 3 Shark ION Robot S87 Battery Replacement, Battery: step 1, image 3 of 3
      • Flip the device so its underside is facing up.
      • Use the Phillips #1 screwdriver to remove the two 14mm screws.
      • Once you have removed the screws, open the battery lid.
      Ask FixBot
    2. Shark ION Robot S87 Battery Replacement: step 2, image 1 of 1
      • Hold both sides of the battery using the plastic tabs.
      • Use the plastic tabs to pull the battery out.
      Ask FixBot
    3. Shark ION Robot S87 Battery Replacement: step 3, image 1 of 2 Shark ION Robot S87 Battery Replacement: step 3, image 2 of 2
      • Disconnect the battery from the device by pulling it out of the circuit.
      Ask FixBot
Adeel Ahmad
256 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 29
All Time: 2,312
