Shark ION Robot R75 Side Sensor Replacement
    1. Shark ION Robot R75 Side Sensor Replacement, Battery: step 1, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement, Battery: step 1, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement, Battery: step 1, image 3 of 3
      • Make sure the robot is shut off by pressing the power button on top.
      • Flip the R75 over so that the underside is facing up.
      • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
      • Remove the battery cover.
      Ask FixBot
    2. Shark ION Robot R75 Side Sensor Replacement: step 2, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 2, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 2, image 3 of 3
      • Be careful when removing the battery, as it will still be connected to a wire.
      • Slowly pull the white tabs outward to remove the battery.
      Ask FixBot
    3. Shark ION Robot R75 Side Sensor Replacement: step 3, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Be careful when removing the connector, as the part can break if too much force is used.
      • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
      • Remove the battery from the device.
      Ask FixBot
    1. Shark ION Robot R75 Side Sensor Replacement, Main Brush: step 4, image 1 of 1
      • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
      Ask FixBot
    2. Shark ION Robot R75 Side Sensor Replacement: step 5, image 1 of 1
      • Pull the main brush slightly to the right to remove it from the compartment.
      Ask FixBot
    3. Shark ION Robot R75 Side Sensor Replacement: step 6, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement: step 6, image 2 of 2
      • Remove the rubber end cap indicated by the red circle.
      • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
      • Inspect this component at least every six months. This time may be less if you have animals.
      Ask FixBot
    1. Shark ION Robot R75 Side Sensor Replacement, Side Brush: step 7, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement, Side Brush: step 7, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement, Side Brush: step 7, image 3 of 3
      • Grab the side brushes by the plastic tab at the base of the bristles, and gently lift up.
      • It's recommended to clean the area with a dry microfiber cloth during replacement, as debris can collect beneath the brush during use.
      Ask FixBot
    1. Shark ION Robot R75 Side Sensor Replacement, Drive Wheel Assembly: step 8, image 1 of 1
      • Flip the R75 to its underside.
      • Make sure the R75 is shut off.
      • For extra security, disconnect the battery by following the prerequisite guide.
      Ask FixBot
    2. Shark ION Robot R75 Side Sensor Replacement: step 9, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 9, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 9, image 3 of 3
      • Using a Torx T15 screwdriver, remove the five screws from the drive wheel assembly.
      • Carefully lift the drive wheel assembly from the wheel well by gently pulling up on the wheel.
      • The assembly will still be connected to the motherboard via a cable, so be sure not to pull so hard that the cable rips.
      Ask FixBot
    3. Shark ION Robot R75 Side Sensor Replacement: step 10, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 10, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 10, image 3 of 3
      • Flip the wheel assembly over and disconnect the cable connector on its underside.
      • Remove the drive wheel assembly.
      • Repeat this process for the other side if necessary.
      Ask FixBot
    1. Shark ION Robot R75 Side Sensor Replacement, Shark ION Robot R75 Caster Wheel: step 11, image 1 of 1
      • Orient the device with the bottom facing up.
      Ask FixBot
    2. Shark ION Robot R75 Side Sensor Replacement: step 12, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 12, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 12, image 3 of 3
      • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
      • Remove the wheel.
      Ask FixBot
    3. Shark ION Robot R75 Side Sensor Replacement: step 13, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 13, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 13, image 3 of 3
      • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
      • Pull the caster assembly up from its slot in the device.
      Ask FixBot
    1. Shark ION Robot R75 Side Sensor Replacement, Top Cover: step 14, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement, Top Cover: step 14, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement, Top Cover: step 14, image 3 of 3
      • Push down on the black tab and remove the dust bin
      Ask FixBot
    2. Shark ION Robot R75 Side Sensor Replacement: step 15, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement: step 15, image 2 of 2
      • Using a Torx TR15 screwdriver, remove the five screws from the bottom cover.
      Ask FixBot
    3. Shark ION Robot R75 Side Sensor Replacement: step 16, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 16, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 16, image 3 of 3
      • Make sure the robot is facing rearward
      • Using a Torx TR15 screwdriver, remove the five screws along the front edge of the device.
      • Pull the bottom part of the bump guard away from the body of the device.
      Ask FixBot
    4. Shark ION Robot R75 Side Sensor Replacement: step 17, image 1 of 3 Shark ION Robot R75 Side Sensor Replacement: step 17, image 2 of 3 Shark ION Robot R75 Side Sensor Replacement: step 17, image 3 of 3
      • Lift the top cover up from the rear of the robot to separate the top cover from the rest of the robot.
      • Be careful when separating the top from the rest of the robot, as the plastic clips can break if excessive force is applied.
      • From here, easy access to all sensors, the main brush motor, and the fan are all granted.
      Ask FixBot
    1. Shark ION Robot R75 Side Sensor Replacement, Side Sensor: step 18, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement, Side Sensor: step 18, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the screw holding down the diagonally vented side cover.
      • Slide the sensor out from the base of the robot
      Ask FixBot
    2. Shark ION Robot R75 Side Sensor Replacement: step 19, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement: step 19, image 2 of 2
      • Lift up the diagonally vented cover on the side of the robot containing the side sensor.
      Ask FixBot
    3. Shark ION Robot R75 Side Sensor Replacement: step 20, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement: step 20, image 2 of 2
      • Disconnect the white connector from the sensor.
      Ask FixBot
    4. Shark ION Robot R75 Side Sensor Replacement: step 21, image 1 of 2 Shark ION Robot R75 Side Sensor Replacement: step 21, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the screw on the sensor.
      • Remove the sensor from its mount.
      Ask FixBot
1 Guide Comment
Curious if anyone ever saw the WiFi die in these? I cannot get the shark WiFi to show so I can add it to the network. I press both the bottoms and the icon flashes but shark WiFi never shows so the app can continue.
Shawn Winters - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 45
All Time: 20,132
