Shark ION Robot 750 Outer Shell Replacement
    1. Shark ION Robot 750 Outer Shell Replacement, Outer Shell: step 1, image 1 of 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: step 1, image 2 of 3 Shark ION Robot 750 Outer Shell Replacement, Outer Shell: step 1, image 3 of 3
      • Make sure the device is completely powered off before working.
      • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
      • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
      • Remove the nine 9.1mm Torx T6 bolts from outer shell.
      Ask FixBot
    2. Shark ION Robot 750 Outer Shell Replacement: step 2, image 1 of 2 Shark ION Robot 750 Outer Shell Replacement: step 2, image 2 of 2
      • Slightly pull front bumper to expose internal wiring.
      • Unplug the device’s front bumper wiring and completely remove front bumper.
      Ask FixBot
    3. Shark ION Robot 750 Outer Shell Replacement: step 3, image 1 of 2 Shark ION Robot 750 Outer Shell Replacement: step 3, image 2 of 2
      • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
      • Gently depress the two tabs on the frame, then lift the frame to remove it.
      Ask FixBot
    4. Shark ION Robot 750 Outer Shell Replacement: step 4, image 1 of 2 Shark ION Robot 750 Outer Shell Replacement: step 4, image 2 of 2
      • Pick up the brush and remove it from the vacuum.
      • Push the brush to your right and lift it.
      Ask FixBot
    5. Shark ION Robot 750 Outer Shell Replacement: step 5, image 1 of 3 Shark ION Robot 750 Outer Shell Replacement: step 5, image 2 of 3 Shark ION Robot 750 Outer Shell Replacement: step 5, image 3 of 3
      • Press and hold the dust bin removal button to slide out the dust bin.
      Ask FixBot
    6. Shark ION Robot 750 Outer Shell Replacement: step 6, image 1 of 1
      • Lift the outer shell to expose the Shark’s interior.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 421
