Shark ION Robot 750 Main Wheel Assembly Replacement
    1. Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: step 1, image 1 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: step 1, image 2 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement, Outer Shell: step 1, image 3 of 3
      • Make sure the device is completely powered off before working.
      • Flip over the vacuum on a flat and uncluttered service with the bottom facing upwards.
      • Remove all seven 9.1mm Torx T15 screws from the device’s front bumper.
      • Remove the nine 9.1mm Torx T6 bolts from outer shell.
      Ask FixBot
    2. Shark ION Robot 750 Main Wheel Assembly Replacement: step 2, image 1 of 2 Shark ION Robot 750 Main Wheel Assembly Replacement: step 2, image 2 of 2
      • Slightly pull front bumper to expose internal wiring.
      • Unplug the device’s front bumper wiring and completely remove front bumper.
      Ask FixBot
    3. Shark ION Robot 750 Main Wheel Assembly Replacement: step 3, image 1 of 2 Shark ION Robot 750 Main Wheel Assembly Replacement: step 3, image 2 of 2
      • Remove the four 9.5mm Torx T6 bolts on the yellow brush frame.
      • Gently depress the two tabs on the frame, then lift the frame to remove it.
      Ask FixBot
    4. Shark ION Robot 750 Main Wheel Assembly Replacement: step 4, image 1 of 2 Shark ION Robot 750 Main Wheel Assembly Replacement: step 4, image 2 of 2
      • Pick up the brush and remove it from the vacuum.
      • Push the brush to your right and lift it.
      Ask FixBot
    5. Shark ION Robot 750 Main Wheel Assembly Replacement: step 5, image 1 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement: step 5, image 2 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement: step 5, image 3 of 3
      • Press and hold the dust bin removal button to slide out the dust bin.
      Ask FixBot
    6. Shark ION Robot 750 Main Wheel Assembly Replacement: step 6, image 1 of 1
      • Lift the outer shell to expose the Shark’s interior.
      Ask FixBot
    1. Shark ION Robot 750 Main Wheel Assembly Replacement, Main Wheel Assembly: step 7, image 1 of 2 Shark ION Robot 750 Main Wheel Assembly Replacement, Main Wheel Assembly: step 7, image 2 of 2
      • Disconnect each of the cable connectors attached to the motherboard to free the wheel assembly from the vacuum for both the left and right wheels.
      • For helpful details on disconnecting different types of connectors, check out the Recognizing and Disconnecting Cable Connectors guide.
      Ask FixBot
    2. Shark ION Robot 750 Main Wheel Assembly Replacement: step 8, image 1 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement: step 8, image 2 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement: step 8, image 3 of 3
      • Use a spudger or your fingers to detach all of the cables from the connectors on the motherboard that connect to the wheels.
      • This guide demonstrates the right wheel removal but you can use this guide to remove the left wheel assembly as well.
      • Unhook the remaining wires that are connected to the back of the wheel.
      • Do not rip the wires when removing them from the wheel and motherboard.
      Ask FixBot
    3. Shark ION Robot 750 Main Wheel Assembly Replacement: step 9, image 1 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement: step 9, image 2 of 3 Shark ION Robot 750 Main Wheel Assembly Replacement: step 9, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the three 12 mm screws that hold the right wheel in place.
      • Be careful not to strip the screws when removing them from the wheel. Take a look at this guide for Screwdriver Best Practices.
      • Remove the right wheel assembly from the socket.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Talia Marquez
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 41
All Time: 580
