Introduction
This guide will instruct you how to remove and replace the wheels of the Shark ION RV754 robot vacuum. The wheels are a crucial component for a functional device so it can clean debris off of the floor as it navigates across various terrains. Replacement wheels for this device can be found on Amazon.
Before you begin this repair, make sure your vacuum is powered off and it's disconnected from the charging dock or charger.
Place the unit on its back with the wheels facing up.
Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
Use your finger to lift off the battery door using the small indent next to it.
Use a TR15 Torx security screwdriver to remove five 13.85 mm screws from the left and right wheel assemblies.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
