Shark ION RV754 Suction Motor Replacement
    1. Shark ION RV754 Suction Motor Replacement, Battery: step 1, image 1 of 1
      • Place the unit on its back with the wheels facing up.
      • Use a Phillips #1 screwdriver to remove the single screw securing the battery compartment door.
      • Use your finger to lift off the battery door using the small indent next to it.
      Ask FixBot
    2. Shark ION RV754 Suction Motor Replacement: step 2, image 1 of 3 Shark ION RV754 Suction Motor Replacement: step 2, image 2 of 3 Shark ION RV754 Suction Motor Replacement: step 2, image 3 of 3
      • Lift the battery out just above the compartment to access the battery connector.
      • Squeeze the tab against the connector and pull it straight up to disconnect it.
      • Remove the battery completely.
      Ask FixBot
    1. Shark ION RV754 Suction Motor Replacement, Wheels: step 3, image 1 of 3 Shark ION RV754 Suction Motor Replacement, Wheels: step 3, image 2 of 3 Shark ION RV754 Suction Motor Replacement, Wheels: step 3, image 3 of 3
      • Use a TR15 Torx security screwdriver to remove five 13.85 mm screws from the left and right wheel assemblies.
      Ask FixBot
    2. Shark ION RV754 Suction Motor Replacement: step 4, image 1 of 3 Shark ION RV754 Suction Motor Replacement: step 4, image 2 of 3 Shark ION RV754 Suction Motor Replacement: step 4, image 3 of 3
      • Lift the wheel assembly out to access the cable connectors that are attached to the wheels.
      • Squeeze the tab against the connector and pull it straight out to disconnect it from the wheel.
      • Remove the wheel assembly.
      • Repeat the steps to remove the other wheel.
      Ask FixBot
    1. Shark ION RV754 Suction Motor Replacement, Suction Motor: step 5, image 1 of 1
      • Press the dust bin latch and slide the bin out to remove it.
      Ask FixBot
    2. Shark ION RV754 Suction Motor Replacement: step 6, image 1 of 3 Shark ION RV754 Suction Motor Replacement: step 6, image 2 of 3 Shark ION RV754 Suction Motor Replacement: step 6, image 3 of 3
      • Remove the 5 9.30 mm screws securing the bumper trim using a Torx TR8 screwdriver.
      • Use an opening tool or spudger to release the clips securing the bumper trip.
      • Carefully pull the bumper trim off the vacuum.
      • Lift the front bumper off of the vacuum.
      Ask FixBot
    3. Shark ION RV754 Suction Motor Replacement: step 7, image 1 of 3 Shark ION RV754 Suction Motor Replacement: step 7, image 2 of 3 Shark ION RV754 Suction Motor Replacement: step 7, image 3 of 3
      • Use a TR8 Torx Security screwdriver to remove the five 13.9 mm screws from the bottom of the vacuum.
      • These 13.9 mm screws are in deep recesses and the TR8 screwdriver will need an extension or a narrow shaft to reach them.
      • Remove the two 9.3 mm screws from the bottom of the vacuum near the dust bin cavity using a TR15 Torx Security screwdriver.
      • To separate the vacuum body, place one hand on the bottom and pull with the other from the brush roll recess.
      Ask FixBot
    4. Shark ION RV754 Suction Motor Replacement: step 8, image 1 of 3 Shark ION RV754 Suction Motor Replacement: step 8, image 2 of 3 Shark ION RV754 Suction Motor Replacement: step 8, image 3 of 3
      • Remove the 6 circuit board wire connectors on the left side of the board as shown.
      • Remove the 6 circuit board wire connectors on the right side of the board using the same method.
      • For helpful tips on removing the cables from the board, take a look at the Recognizing and Disconnecting Cable Connectors guide.
      • Be careful when disconnecting the wire connectors from the circuit board to avoid damage to the wires, sockets, or circuit board.
      • It is a good idea to keep a reference picture for reattaching the wires later, since many of them are very similar in color and size.
      Ask FixBot
    5. Shark ION RV754 Suction Motor Replacement: step 9, image 1 of 2 Shark ION RV754 Suction Motor Replacement: step 9, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the five 9.80 mm screws from the circuit board.
      • Gently remove the circuit board by pulling up on it as shown and set it aside.
      Ask FixBot
    6. Shark ION RV754 Suction Motor Replacement: step 10, image 1 of 3 Shark ION RV754 Suction Motor Replacement: step 10, image 2 of 3 Shark ION RV754 Suction Motor Replacement: step 10, image 3 of 3
      • Remove the three 11.6 mm screws securing the suction motor using a Phillips #1 screwdriver.
      • Disconnect the remaining wires connected to the suction motor and move the wires aside to avoid pulling on them when removing the suction motor.
      • Pull up on the suction motor to remove it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 98
All Time: 443
