Up to 20% off select tools
Shark ION RV754 Filter Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
65
All Time:
610
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the two dust filters for the Shark RV754. The filters are responsible for catching fine dust particles that would otherwise float into the air as the vacuum operates. The filters may become clogged over time with regular use. Dirty or overused filters restrict airflow, reducing suction power and the capability to pick up debris. Filters can be cleaned manually to improve effectiveness; however, if they are damaged, they may need to be replaced with new filters.
The vacuum comes with only 1 set of filters, so extras will need to be purchased from Shark's website or third-party retailers like Amazon.
Before you begin, make sure that the device is powered off and disconnected from the charging dock.
    1. Shark ION RV754 Filter Replacement, Dust Filter(s): step 1, image 1 of 1
      • Flip the robot vacuum upside down so the wheels are facing up.
      • Press the dust bin removal latch and slide out the dust bin.
      Ask FixBot
    2. Shark ION RV754 Filter Replacement: step 2, image 1 of 1
      • Pull out the blue filter on the inside of the dust tray.
      • This filter is not attached to anything and should come out easily.
      Ask FixBot
    3. Shark ION RV754 Filter Replacement: step 3, image 1 of 1
      • To access the second filter, open the debris tray.
      • Hold the tray with two fingers at the indicated holes, and use your other hand to pull from the opposite side of the tray.
      Ask FixBot
    4. Shark ION RV754 Filter Replacement: step 4, image 1 of 3 Shark ION RV754 Filter Replacement: step 4, image 2 of 3 Shark ION RV754 Filter Replacement: step 4, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the 7.3 mm screw securing the second filter.
      • Lift the filter out from the same side where you removed the screw.
      Ask FixBot
Author
with
James Holland
370 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 65
All Time: 610
