Up to 20% off select tools
Shark Flex DuoClean Side Component Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
72
All Time:
2,420
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
You will need a T10 Security Torx screwdriver and an iFixit Opening Tool to open the side components.
    1. Shark Flex DuoClean Side Component Replacement, Garage Door: step 1, image 1 of 2 Shark Flex DuoClean Side Component Replacement, Garage Door: step 1, image 2 of 2
      • Open the garage door by sliding both of the release buttons away from you.
      • Lift off the garage door.
      Ask FixBot
    1. Shark Flex DuoClean Side Component Replacement, Side Component: step 2, image 1 of 2 Shark Flex DuoClean Side Component Replacement, Side Component: step 2, image 2 of 2
      • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
      Ask FixBot
    2. Shark Flex DuoClean Side Component Replacement: step 3, image 1 of 2 Shark Flex DuoClean Side Component Replacement: step 3, image 2 of 2
      • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
      Ask FixBot
    3. Shark Flex DuoClean Side Component Replacement: step 4, image 1 of 1
      • Use the iFixit Opening Tool to pry the side of the vacuum open.
      Ask FixBot
    4. Shark Flex DuoClean Side Component Replacement: step 5, image 1 of 1
      • Remove the side component with your hands.
      Ask FixBot
Author
with
caoimhe
1,007 Reputation
4 Guides authored
Cal Poly, Team S17-G5, White Fall 2018 Member of Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 2,420
