Shark AI Ultra AV2511AE Side Brush Replacement
    1. Shark AI Ultra AV2511AE Side Brush Replacement, Side Brush: step 1, image 1 of 2 Shark AI Ultra AV2511AE Side Brush Replacement, Side Brush: step 1, image 2 of 2
      • Orient the device upside-down.
      • Holding the brush with two fingers firmly, use a Torx TR9 screwdriver to remove the 5 mm screw.
      Ask FixBot
    2. Shark AI Ultra AV2511AE Side Brush Replacement: step 2, image 1 of 2 Shark AI Ultra AV2511AE Side Brush Replacement: step 2, image 2 of 2
      • Remove the side brush.
      Ask FixBot
    3. Shark AI Ultra AV2511AE Side Brush Replacement, Look out for the tiny bracing bracket: step 3, image 1 of 3 Shark AI Ultra AV2511AE Side Brush Replacement, Look out for the tiny bracing bracket: step 3, image 2 of 3 Shark AI Ultra AV2511AE Side Brush Replacement, Look out for the tiny bracing bracket: step 3, image 3 of 3
      • Look out for a tiny metal bracket/clip stuck inside the old brush which may need to be removed and inserted into the replacement brush. These clips slide into keyed slots on the spinning brush driveshaft; they'd fit on rotated 180 degrees but not 90. Recommend doing one brush at a time and looking for these clips and their orientation.
      Ask FixBot
Gisela Benavides
257 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 100
All Time: 1,149
