Up to 20% off select tools
Shank Button Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
13
Past 7 Days:
44
Past 30 Days:
157
All Time:
1,664
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
A shank button is any button with a loop (or shank) on the back. This type of button is very easy to replace and will extend the life of your garment!
    1. Shank Button Replacement, Shank Button: step 1, image 1 of 3 Shank Button Replacement, Shank Button: step 1, image 2 of 3 Shank Button Replacement, Shank Button: step 1, image 3 of 3
      • Remove your loose button (if necessary).
      • If the button is already missing, remove any loose threads from your garment.
      • Mark where the button was on the garment to hold place (a felt tip pen works fine, just keep the marking small)
      Ask FixBot
    2. Shank Button Replacement: step 2, image 1 of 3 Shank Button Replacement: step 2, image 2 of 3 Shank Button Replacement: step 2, image 3 of 3
      • Measure out your thread. An easy measuring reference is the length of one arm fully extended.
      • Thread your needle.
      • Pull the thread until two equal parts are on either side of the needle.
      • Tie a knot in the end of your thread (both ends should be tied together creating a double thread).
      Ask FixBot
    3. Shank Button Replacement: step 3, image 1 of 3 Shank Button Replacement: step 3, image 2 of 3 Shank Button Replacement: step 3, image 3 of 3
      • Insert your needle into the marked space where your needle should go on the top side of the garment (that way the button will hide your knot).
      • Pull the thread until the knot rests on the fabric.
      • Insert your needle into the shank on the back of your button.
      • Pull the thread until the button rests on the fabric.
      • Insert the needle back into the same space on your fabric. Repeat the above instructions 5 times or until the button is firmly attached.
      Ask FixBot
    4. Shank Button Replacement: step 4, image 1 of 3 Shank Button Replacement: step 4, image 2 of 3 Shank Button Replacement: step 4, image 3 of 3
      • To tie off your thread, insert the needle back into the fabric near your previous stitches.
      • Pull thread until there is a small loop (do not pull flush with fabric).
      • Insert the needle into the thread loop and pull through.
      • Pull the thread until the loop closes and a knot is formed.
      Ask FixBot
    5. Shank Button Replacement: step 5, image 1 of 3 Shank Button Replacement: step 5, image 2 of 3 Shank Button Replacement: step 5, image 3 of 3
      • Trim any excess thread from the button area.
      • Enjoy your newly repaired item!
      Ask FixBot
Finish Line
Author
with
Rebekah Kilpatrick
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 44
Past 30 Days: 157
All Time: 1,664
