Sewing a small Hole for a Seamless Fix
  1. Sewing a small Hole for a Seamless Fix, Sewing a small Hole for a Seamless Fix: step 1, image 1 of 1
    • Ensure the hole is small enough to be easily repaired with sewing.
  2. Sewing a small Hole for a Seamless Fix: step 2, image 1 of 2 Sewing a small Hole for a Seamless Fix: step 2, image 2 of 2
    • Thread the needle with a length of thread doubling it over at the end to secure it.
    • At a good length (depending on the size of the hole), cut off the excess and tie a knot at the end of the thread.
  3. Sewing a small Hole for a Seamless Fix: step 3, image 1 of 1
    • Position the sweater with the hole facing up on a flat surface. Make sure your sweater is inside out.
    • This will make the stitches not as visible.
  4. Sewing a small Hole for a Seamless Fix: step 4, image 1 of 3 Sewing a small Hole for a Seamless Fix: step 4, image 2 of 3 Sewing a small Hole for a Seamless Fix: step 4, image 3 of 3
    • Insert the needle into the fabric slightly above the hole, pulling it through the backside of the sweater, and repeat this process along the edges of the hole to create a series of stitches.
  5. Sewing a small Hole for a Seamless Fix: step 5, image 1 of 1
    • Continue stitching back and forth across the hole in a zig-zag pattern until it is completely closed, ensuring stitches are tight and secure.
  6. Sewing a small Hole for a Seamless Fix: step 6, image 1 of 2 Sewing a small Hole for a Seamless Fix: step 6, image 2 of 2
    • Tie off the thread by creating a small knot at the end of the stitching and trimming any excess thread with scissors.
  7. Sewing a small Hole for a Seamless Fix: step 7, image 1 of 1
    • Reverse your sweater outside in. Tug at the area slightly to ensure the stitches hold and the fabric remains intact.
Finish Line
Kendra Tejada
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 62
All Time: 682
