Up to 20% off select tools
Sew-on Patch
Views: 11K
View statistics:
Past 24 Hours:
7
Past 7 Days:
39
Past 30 Days:
188
All Time:
11,078
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Sew-on Patch
Tools
Introduction
Go to step 1 ↓
Patch jeans with a sew-on patch. This technique is also applicable for adding patches to bags, bandanas, and boy-scout uniforms. Patches can also be sewn on by hand.
    1. Sew-on Patch, Sew-on Patch: step 1, image 1 of 2 Sew-on Patch, Sew-on Patch: step 1, image 2 of 2
      • Examine the damage. Clip any loose threads and remove any debris from the tear.
      • Grab a trendy patch.
      Ask FixBot
    2. Sew-on Patch: step 2, image 1 of 2 Sew-on Patch: step 2, image 2 of 2
      • Position the patch over the hole.
      • Any patch you use should overlap the damage by at least 1/8".
      Ask FixBot
    3. Sew-on Patch: step 3, image 1 of 3 Sew-on Patch: step 3, image 2 of 3 Sew-on Patch: step 3, image 3 of 3
      • Pin the patch to the jeans.
      • Be sure to only pin the patch to one layer of denim, or you will sew the pants shut.
      Ask FixBot
    4. Sew-on Patch: step 4, image 1 of 3 Sew-on Patch: step 4, image 2 of 3 Sew-on Patch: step 4, image 3 of 3
      • Slide the jeans into the sewing machine, positioning the needle over the edge of the patch.
      • Be sure you only have one layer of the jeans between the needle and the sewing machine arm, or you will sew the pants shut.
      Ask FixBot
    5. Sew-on Patch: step 5, image 1 of 2 Sew-on Patch: step 5, image 2 of 2
      • Lower the pressor foot.
      • Sew along the edge of the patch.
      • Remove the pins before you get to them.
      • Sewing over a pin can bend or break the needle.
      Ask FixBot
    6. Sew-on Patch: step 6, image 1 of 2 Sew-on Patch: step 6, image 2 of 2
      • Continue sewing around the patch, lifting the pressor foot to turn at corners of the patch.
      Ask FixBot
    7. Sew-on Patch: step 7, image 1 of 3 Sew-on Patch: step 7, image 2 of 3 Sew-on Patch: step 7, image 3 of 3
      • When you come all the way around, overlap the first two or three stitches.
      • Lift the needle and pressor foot.
      • Slide the jeans out of the sewing machine.
      • Clip any threads, and admire your work.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 188
All Time: 11,078
