Up to 20% off select tools
Service door disassembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
71
All Time:
798
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Service door disassembly, Remove the battery: step 1, image 1 of 3 Service door disassembly, Remove the battery: step 1, image 2 of 3 Service door disassembly, Remove the battery: step 1, image 3 of 3
      • Turn the laptop upside down and gently lay it down on a flat surface.
      • Slide the battery release latch to the right and the battery will pop up slightly.
      • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
      • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
      Ask FixBot
    1. Service door disassembly, Remove the captive screw of the service door: step 2, image 1 of 1
      • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
      Ask FixBot
    2. Service door disassembly, Remove the service door: step 3, image 1 of 3 Service door disassembly, Remove the service door: step 3, image 2 of 3 Service door disassembly, Remove the service door: step 3, image 3 of 3
      • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
      • Continue along the short edges.
      • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
      Ask FixBot
    3. Service door disassembly, Identify the components: step 4, image 1 of 1
      • RAM memory modules
      • HDD (Hard Disk Drive)
      • mSATA SSD slot
      • Wifi & BT module (Wireless card)
      Ask FixBot
Author
with
Roberto Bartolacci
1,548 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 71
All Time: 798
