Up to 20% off select tools
Service Panel Disassembly
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
74
All Time:
635
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Pro Data is designed for repair: with two standard screws, its service panel can be removed, permitting access to the chassis interior for component replacement.
    1. Service Panel Disassembly, Remove Service Panel Screws: step 1, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
      • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
      Ask FixBot
    2. Service Panel Disassembly, Dislodge Service Panel: step 2, image 1 of 3 Service Panel Disassembly, Dislodge Service Panel: step 2, image 2 of 3 Service Panel Disassembly, Dislodge Service Panel: step 2, image 3 of 3
      • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
      • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
      Ask FixBot
Author
with
iodyne
462 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 74
All Time: 635
