Sennheiser Momentum 4 Right Driver Assembly Replacement
  1. Sennheiser Momentum 4 Right Driver Assembly Replacement, Right Driver Assembly: step 1, image 1 of 1
    • On the right ear piece, insert an opening tool into the gap between the ear pad and the driver housing.
    • Gently pry the ear pad away from the driver housing until the ear pad fully releases.
    • Remove the right ear pad.
    Ask FixBot
  2. Sennheiser Momentum 4 Right Driver Assembly Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove four 6.5mm screws that secure the right driver housing.
    Ask FixBot
  3. Sennheiser Momentum 4 Right Driver Assembly Replacement: step 3, image 1 of 1
    • Insert a spudger into the seam between the driver housing and chassis.
    • Gently pry the driver housing up and out of the chassis, with care not to strain the connected cables.
    Ask FixBot
  4. Sennheiser Momentum 4 Right Driver Assembly Replacement: step 4, image 1 of 2 Sennheiser Momentum 4 Right Driver Assembly Replacement: step 4, image 2 of 2
    • Flip up the two black ZIF locking flaps that secure the two bronze ribbon cables attached to the driver assembly.
    • Disconnect the two ribbon cables and set the driver assembly to the side of the chassis.
    • Desolder the two speaker cable motherboard connections.
    • Remove the driver assembly.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 Guide Comments
Hello!
I recently had to disassemble my headphones. After reassembling them, I noticed that some frequencies seemed to be missing. Could the problem be related to the cable inside?
Kova - Reply Share
Went smoothly, (didn’t do soldering step as I was disconnecting cable to troubleshoot static)
was hesitant to put so much centripetal force on the ear muffs since I didn’t want to break the tabs like I did so many times on the Sony xm5’s though.
But just had to move it enough for one to pop out then wiggle the rest out. Same with the actual chassis holding the board inside
CannibalToast - Reply Share
Past 24 Hours: 12
Past 7 Days: 51
Past 30 Days: 234
All Time: 2,672
