Sennheiser Momentum 4 Left Driver Assembly Replacement
  1. Sennheiser Momentum 4 Left Driver Assembly Replacement, Ear Pads: step 1, image 1 of 2 Sennheiser Momentum 4 Left Driver Assembly Replacement, Ear Pads: step 1, image 2 of 2
    • Insert a spudger into the seam between the left ear pad and driver assembly.
    • Gently pry around the perimeter of the ear pad until it fully releases.
    • Remove the left ear pad.
    • Repeat for the right ear pad if necessary.
    Ask FixBot
  2. Sennheiser Momentum 4 Left Driver Assembly Replacement, Battery: step 2, image 1 of 2 Sennheiser Momentum 4 Left Driver Assembly Replacement, Battery: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 6.5 mm screws that secure the left driver housing.
    Ask FixBot
  3. Sennheiser Momentum 4 Left Driver Assembly Replacement: step 3, image 1 of 1
    • Insert the flat end of a spudger into the driver housing seam.
    • Gently pry the driver housing up and out, with care not to strain or damage the connected cables.
    Ask FixBot
  4. Sennheiser Momentum 4 Left Driver Assembly Replacement: step 4, image 1 of 1
    • Carefully lift away the driver housing out and flip it over to reveal the battery cover.
    • Be careful that there is flex cable connected to daughterboard. First disconnect it and then flip it over.
    • Use tweezers to pull the white battery connector directly out of the daughterboard socket.
    • It disconnects similarly to removing a plug from a socket.
    Ask FixBot
  5. Sennheiser Momentum 4 Left Driver Assembly Replacement: step 5, image 1 of 1
    • Use the flat end of a spudger to pry open the retaining clips on the battery cover and remove it carefully.
    Ask FixBot
  6. Sennheiser Momentum 4 Left Driver Assembly Replacement: step 6, image 1 of 2 Sennheiser Momentum 4 Left Driver Assembly Replacement: step 6, image 2 of 2
    • Insert the flat end of a spudger between the lower edge of the battery and the battery housing.
    • Do not bend, warp, or puncture the battery.
    • Gently lift the battery upward to release the adhesive that secures the battery.
    • If necessary, use a hairdryer to lightly heat the battery to loosen the adhesive.
    • Remove the battery.
    Ask FixBot
  7. Sennheiser Momentum 4 Left Driver Assembly Replacement, Left Driver Assembly: step 7, image 1 of 1
    • Desolder the two driver assembly motherboard connections.
    • Remove the driver assembly.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
25,036 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 41
Past 30 Days: 199
All Time: 2,581
