Introduction
If you're having inconsistencies related to your Sennheiser Accentum Wireless headphones' battery life, this guide demonstrates how to remove the battery for replacement.
Before opening the device, first check the charging port for any debris that may be impacting charging connection. For small amounts of debris, you can use an ESD-safe brush or small dust blower. You can also try testing different charging cables and testing different outlets. Checkout our troubleshooting guide for more tips.
This guide requires the use of heat and a decent amount of force to remove the battery because it is held in place by a foam adhesive.
When interacting with electronic components it's important to minimize ESD. This means avoiding the use of metal tools with electrical components. The steps of this guide should ideally be followed in an area of between 40% and 60% to reduce the chances of ESD.
Remove the four black foam screw covers.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
