Up to 20% off select tools
Segway i2 Inner Tube Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
41
Past 30 Days:
166
All Time:
6,061
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Segway tires are thick and designed specifically for maneuverability. These tires are tedious to replace, but will save a great deal of money by being restored rather than re-bought. The tools needed will be three flat head screwdrivers, a large persuasion bar, and a clamp. There is a slight injury warning, however, to combat this, the user might need multiple people for assistance.
    1. Segway i2 Inner Tube Replacement, Inner Tube: step 1, image 1 of 1
      • After the tire has been removed from the Segway body put the tire on a strong, level surface
      Ask FixBot
    2. Segway i2 Inner Tube Replacement: step 2, image 1 of 1
      • Use the clamp to squeeze the rubber of the tire until the tire pops off of the rim. Repeat this process until the whole tire is popped off of the rim.
      Ask FixBot
    3. Segway i2 Inner Tube Replacement: step 3, image 1 of 1
      • Use your hands to squish the tire all the way around the sides to make sure the tire is off the Segway rim completely.
      Ask FixBot
    4. Segway i2 Inner Tube Replacement: step 4, image 1 of 2 Segway i2 Inner Tube Replacement: step 4, image 2 of 2
      • (a) Now that the tire is popped off of the rim, use the persuasion bar to get under the rubber of the tire and put it over the rim. (b) When you pull the rubber of the tire over the rim be sure to push the persuasion bar towards the opposite side of the tire.
      • If the rubber is not going over the rim, verify that steps 2 and 3 have been completed and the tire is completely popped off of the rim.
      Ask FixBot
    5. Segway i2 Inner Tube Replacement: step 5, image 1 of 1
      • Using the flathead screwdriver, wedge it between the rubber and the rim to prevent the tire from returning to its original position.
      Ask FixBot
    6. Segway i2 Inner Tube Replacement: step 6, image 1 of 2 Segway i2 Inner Tube Replacement: step 6, image 2 of 2
      • Continue pulling the rubber over the rim until the edge of the rubber is visible all the way around the tire.
      Ask FixBot
    7. Segway i2 Inner Tube Replacement: step 7, image 1 of 1
      • Push on the outer face of the tire to cause the tire to pop out of place.
      • Do not remove the rim from the tire, just make sure that the rim can be pulled far enough so the inner tube can be pulled out and replaced.
      Ask FixBot
    8. Segway i2 Inner Tube Replacement: step 8, image 1 of 1
      • Pull out the inner tube as you rotate tire. The inner tube should be fully pulled out of the tire by the time you finish this step.
      • Make sure the rim and the rubber of the tire are not separated from each other when you start to replace the inner tube of the tire.
      Ask FixBot
    9. Segway i2 Inner Tube Replacement: step 9, image 1 of 1
      • Push the nub of the inner tube out of the rim of the tire through the hole it was already in.
      • Make sure there is no cap on the valve stem when you remove the inner tube from the tire.
      Ask FixBot
    10. Segway i2 Inner Tube Replacement: step 10, image 1 of 1
      • Take the new inner tube for the Segway and make sure it’s deflated and is the right model number for your Segway.
      Ask FixBot
    11. Segway i2 Inner Tube Replacement: step 11, image 1 of 1
      • When you are sure you have the correct inner tube, take the nub of the new inner tube and put it back into the hole of the rim that the old inner tube nub was removed from previously.
      Ask FixBot
    12. Segway i2 Inner Tube Replacement: step 12, image 1 of 1
      • Wrap the new inner tube around the rim.
      Ask FixBot
    13. Segway i2 Inner Tube Replacement: step 13, image 1 of 1
      • Tuck the inner tube inside the tire by using a rolling motion with your hand.
      • Verify that you cannot see any of the inner tube before proceeding.
      Ask FixBot
    14. Segway i2 Inner Tube Replacement: step 14, image 1 of 1
      • Use the persuasion bar to begin pulling the rubber back over the rim of the tire. When you pull the rubber back over the tire, push the persuasion bar away from you and towards the other side of the tire to put the rubber of the tire back onto the rim.
      • When you put the tire back on, be sure that the tire is loose on the rim so that the rubber will be able to be on the entire tire by the time you finish the step.
      Ask FixBot
    15. Segway i2 Inner Tube Replacement: step 15, image 1 of 2 Segway i2 Inner Tube Replacement: step 15, image 2 of 2
      • Make sure the tire isn’t all the way on the rim, otherwise the last quarter of the tire will be almost impossible to pry back into place. To make sure the tire is not on the rim, repeat what was done in step three when the tire was squished off of the rim.
      Ask FixBot
    16. Segway i2 Inner Tube Replacement: step 16, image 1 of 1
      • Once the inner tube has been completely seated again, then you can inflate the inner tube and will successfully have a replaced inner tube in your Segway tire.
      Ask FixBot
The tire is essential to the function of the Segway and should be maintained in order to maximize the functionality and experience of the Segway. The Segway Company is known for its reliability and the enjoyable experience. That being said, this guide will provide a reliable way to ensure the safety and experience of the Segway by repairing the most important parts of the Segway: its two tires. It is critical that they are fixed and maintained. Through this guide we will show the reader how to fix their Segway i2 tire to provide a guide to a simple fix that will be much more cost effective than buying a whole new tire.
5 other people completed this guide.
Author
with
Janell Hoff
221 Reputation
1 Guide authored
1 Guide Comment
What is the the thickness for the tire it self\
JOE MEM - Reply Share
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 166
All Time: 6,061
