Segway Ninebot Max Front Tire Repacement
    1. Segway Ninebot Max Front Tire Repacement, Front Tire: step 1, image 1 of 3 Segway Ninebot Max Front Tire Repacement, Front Tire: step 1, image 2 of 3 Segway Ninebot Max Front Tire Repacement, Front Tire: step 1, image 3 of 3
      • Before beginning the guide make sure the scooter is off and placed on a stand or table for easier access to work on.
      • Remove the cap and reflection tag using a slotted screwdriver.
      Ask FixBot
    2. Segway Ninebot Max Front Tire Repacement: step 2, image 1 of 3 Segway Ninebot Max Front Tire Repacement: step 2, image 2 of 3 Segway Ninebot Max Front Tire Repacement: step 2, image 3 of 3
      • Use 3 mm Allen key to loosen three hexagon screws from each side of the wheel.
      Ask FixBot
    3. Segway Ninebot Max Front Tire Repacement: step 3, image 1 of 2 Segway Ninebot Max Front Tire Repacement: step 3, image 2 of 2
      • Snap the covers away from the scooter from both sides.
      • Remove the covers slowly and steadily to avoid breaking it.
      Ask FixBot
    4. Segway Ninebot Max Front Tire Repacement: step 4, image 1 of 2 Segway Ninebot Max Front Tire Repacement: step 4, image 2 of 2
      • To detach the brake, use a 10 mm Allen wrench to remove the bolt from the tire that is attached with the brake.
      Ask FixBot
    5. Segway Ninebot Max Front Tire Repacement: step 5, image 1 of 2 Segway Ninebot Max Front Tire Repacement: step 5, image 2 of 2
      • Use a 15 mm socket wrench to remove 15mm bolt from the tire of the scooter on both sides of the front wheel.
      Ask FixBot
    6. Segway Ninebot Max Front Tire Repacement: step 6, image 1 of 1
      • Pull down the tire and remove it from the frame.
      Ask FixBot
7 other people completed this guide.
Shafran Jamal
309 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 103
Past 30 Days: 437
All Time: 16,231
