Up to 20% off select tools
Segway Ninebot Max Battery Replacement
Views: 65K
View statistics:
Past 24 Hours:
20
Past 7 Days:
183
Past 30 Days:
824
All Time:
64,832
Comments: 11
4 comments on steps, 7 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
With use and over time, electric batteries degrade (loss of power/strength and capacity). This guide will show you how to replace the battery of your Segway Ninebot Max Scooter, allowing you to go the intended speed and distance instead of using the degraded battery, which would only get you approximately 50-75% of the intended power.
    1. Segway Ninebot Max Battery Replacement, Remove the base plate: step 1, image 1 of 2 Segway Ninebot Max Battery Replacement, Remove the base plate: step 1, image 2 of 2
      • Flip the scooter upside down and unscrew the 18 screws holding the base plate using a Security Torx T15 screwdriver.
      Ask FixBot
    2. Segway Ninebot Max Battery Replacement, Remove the old battery: step 2, image 1 of 2 Segway Ninebot Max Battery Replacement, Remove the old battery: step 2, image 2 of 2
      • Unscrew the 10 screws that hold the battery onto the frame and remove the battery from the enclosure.
      • Unplug any connectors that connect the battery and scooter together.
      Ask FixBot
    3. Segway Ninebot Max Battery Replacement, Place the new battery inside: step 3, image 1 of 1
      • Place the new battery inside the enclosure and reinstall the 10 screws (if needed), bonding the battery to the scooter.
      Ask FixBot
    4. Segway Ninebot Max Battery Replacement, Connect the battery: step 4, image 1 of 2 Segway Ninebot Max Battery Replacement, Connect the battery: step 4, image 2 of 2
      • Connect the pins from the battery and scooter together.
      • Make sure to tuck in the wiring.
      Ask FixBot
    5. Segway Ninebot Max Battery Replacement, Test the battery: step 5, image 1 of 1
      • Turn on the scooter and accelerate to make sure there are no errors and the scooter is running.
      Ask FixBot
    6. Segway Ninebot Max Battery Replacement, Reattach the base plate: step 6, image 1 of 2 Segway Ninebot Max Battery Replacement, Reattach the base plate: step 6, image 2 of 2
      • Line up the base plate and tighten it with all 18 screws using a Security Torx T15 Allen Key.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
11 other people completed this guide.
Author
with
sunny sanghera
323 Reputation
1 Guide authored
7 Guide Comments
Do you know where I can purchase a replacement battery for the Ninebot Max? I can't seem to find one.
Chip Bates - Reply Share
If you find a new battery will you put me onto it aswell I need one do you know how much they are thanks in advance
Andrew Leslie - Reply Share
Do you guys recommend purchasing any brand battery charger for your Ninebot Segway Scooter 🛴 or should I stick with the actual "Segway" brand charger from their official site??? Is there really a difference or is one just as good as the other???
Jessica Loftis - Reply Share
looking for battery for ninebot zing e10 scooter
Isaac L - Reply Share
Am o problema, când bateria trotinete ajunge la jumate se oprește, un răspuns va rog!
Gabi Gabrieluu - Reply Share
Past 24 Hours: 20
Past 7 Days: 183
Past 30 Days: 824
All Time: 64,832
