Sega Saturn Power Supply Replacement
    1. Sega Saturn Power Supply Replacement, Battery: step 1, image 1 of 2 Sega Saturn Power Supply Replacement, Battery: step 1, image 2 of 2
      • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
      Ask FixBot
    2. Sega Saturn Power Supply Replacement: step 2, image 1 of 3 Sega Saturn Power Supply Replacement: step 2, image 2 of 3 Sega Saturn Power Supply Replacement: step 2, image 3 of 3
      • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
      Ask FixBot
    3. Sega Saturn Power Supply Replacement: step 3, image 1 of 3 Sega Saturn Power Supply Replacement: step 3, image 2 of 3 Sega Saturn Power Supply Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use the ESD safe tweezers to pull the battery out of its slot.
      Ask FixBot
    1. Sega Saturn Power Supply Replacement, Case: step 4, image 1 of 3 Sega Saturn Power Supply Replacement, Case: step 4, image 2 of 3 Sega Saturn Power Supply Replacement, Case: step 4, image 3 of 3
      • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
      Ask FixBot
    2. Sega Saturn Power Supply Replacement: step 5, image 1 of 3 Sega Saturn Power Supply Replacement: step 5, image 2 of 3 Sega Saturn Power Supply Replacement: step 5, image 3 of 3
      • Flip the device over so it rests right side up.
      • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
      Ask FixBot
    1. Sega Saturn Power Supply Replacement, Power Supply: step 6, image 1 of 2 Sega Saturn Power Supply Replacement, Power Supply: step 6, image 2 of 2
      • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
      Ask FixBot
    2. Sega Saturn Power Supply Replacement: step 7, image 1 of 3 Sega Saturn Power Supply Replacement: step 7, image 2 of 3 Sega Saturn Power Supply Replacement: step 7, image 3 of 3
      • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
      Ask FixBot
    3. Sega Saturn Power Supply Replacement: step 8, image 1 of 2 Sega Saturn Power Supply Replacement: step 8, image 2 of 2
      • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
      Ask FixBot
    4. Sega Saturn Power Supply Replacement: step 9, image 1 of 3 Sega Saturn Power Supply Replacement: step 9, image 2 of 3 Sega Saturn Power Supply Replacement: step 9, image 3 of 3
      • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
      Ask FixBot
Jan Ulloa
630 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2019 Member of USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
3 Members
72 Guides authored
1 Guide Comment
Incomplete. This is "Removal" only. "Replacement" indicates that there is a replacement part. Where is the replacement part? Where do you obtain/purchase it? No description of the replacement part or link to obtain it. Clarify.
BGPhilbin - Reply Share
Past 24 Hours: 9
Past 7 Days: 52
Past 30 Days: 175
All Time: 8,836
