Sega Saturn Motherboard Replacement
  1. Sega Saturn Motherboard Replacement, Battery: step 1, image 1 of 2 Sega Saturn Motherboard Replacement, Battery: step 1, image 2 of 2
    • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
    Ask FixBot
  2. Sega Saturn Motherboard Replacement: step 2, image 1 of 3 Sega Saturn Motherboard Replacement: step 2, image 2 of 3 Sega Saturn Motherboard Replacement: step 2, image 3 of 3
    • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
    Ask FixBot
  3. Sega Saturn Motherboard Replacement: step 3, image 1 of 3 Sega Saturn Motherboard Replacement: step 3, image 2 of 3 Sega Saturn Motherboard Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use the ESD safe tweezers to pull the battery out of its slot.
    Ask FixBot
  4. Sega Saturn Motherboard Replacement, Case: step 4, image 1 of 3 Sega Saturn Motherboard Replacement, Case: step 4, image 2 of 3 Sega Saturn Motherboard Replacement, Case: step 4, image 3 of 3
    • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
    Ask FixBot
  5. Sega Saturn Motherboard Replacement: step 5, image 1 of 3 Sega Saturn Motherboard Replacement: step 5, image 2 of 3 Sega Saturn Motherboard Replacement: step 5, image 3 of 3
    • Flip the device over so it rests right side up.
    • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
    Ask FixBot
  6. Sega Saturn Motherboard Replacement, Power Supply: step 6, image 1 of 2 Sega Saturn Motherboard Replacement, Power Supply: step 6, image 2 of 2
    • Unplug the power button plug on the power supply board. Use the iFixit opening tool if necessary.
    Ask FixBot
  7. Sega Saturn Motherboard Replacement: step 7, image 1 of 3 Sega Saturn Motherboard Replacement: step 7, image 2 of 3 Sega Saturn Motherboard Replacement: step 7, image 3 of 3
    • Remove the two black 11.4mm standoff screws on the back of the Sega Saturn holding the power socket in place. These screws are tight and easily stripped, so it's suggested to use a standoff screw head.
    Ask FixBot
  8. Sega Saturn Motherboard Replacement: step 8, image 1 of 2 Sega Saturn Motherboard Replacement: step 8, image 2 of 2
    • Remove the metallic 12.3mm JIS#1 screw holding down the power supply board.
    Ask FixBot
  9. Sega Saturn Motherboard Replacement: step 9, image 1 of 3 Sega Saturn Motherboard Replacement: step 9, image 2 of 3 Sega Saturn Motherboard Replacement: step 9, image 3 of 3
    • Lift the power supply board out of its socket, minding the pins that connect it to the motherboard. Some force will be required, but be careful when lifting or shaking the power supply board out.
    Ask FixBot
  10. Sega Saturn Motherboard Replacement, Power Button: step 10, image 1 of 3 Sega Saturn Motherboard Replacement, Power Button: step 10, image 2 of 3 Sega Saturn Motherboard Replacement, Power Button: step 10, image 3 of 3
    • Remove the metallic 13.7mm JIS#1 screw on the right of the Power Button.
    • Remove the metallic 12.4mm JIS#1 screw on the left of the Power Button.
    Ask FixBot
  11. Sega Saturn Motherboard Replacement: step 11, image 1 of 2 Sega Saturn Motherboard Replacement: step 11, image 2 of 2
    • Push the plastic resting tray’s pin located here.
    • Remove the plastic resting tray to free the wire between the power supply board and the button.
    • Remove the power button when the wire is free.
    Ask FixBot
  12. Sega Saturn Motherboard Replacement, Disc Reader: step 12, image 1 of 1
    • Do not touch the laser reader, as smudges have been reported to ruin it.
    Ask FixBot
  13. Sega Saturn Motherboard Replacement: step 13, image 1 of 2 Sega Saturn Motherboard Replacement: step 13, image 2 of 2
    • Pull firmly on the ribbon cable from the end on the motherboard.
    • Don't worry about pulling it out of its socket; it can be plugged back in.
    Ask FixBot
  14. Sega Saturn Motherboard Replacement: step 14, image 1 of 3 Sega Saturn Motherboard Replacement: step 14, image 2 of 3 Sega Saturn Motherboard Replacement: step 14, image 3 of 3
    Buy
    • Pry the second cable out of its socket on the disk reader with the iFixit opening tool or ESD safe tweezers. When the lip of the cable gets enough distance out of the socket, it can be wiggled free.
    Ask FixBot
  15. Sega Saturn Motherboard Replacement: step 15, image 1 of 3 Sega Saturn Motherboard Replacement: step 15, image 2 of 3 Sega Saturn Motherboard Replacement: step 15, image 3 of 3
    • Lift the laser reader slowly out of its slot hosted by these four pins. There is a screw underneath with a cable attached to the motherboard.
    Ask FixBot
  16. Sega Saturn Motherboard Replacement: step 16, image 1 of 3 Sega Saturn Motherboard Replacement: step 16, image 2 of 3 Sega Saturn Motherboard Replacement: step 16, image 3 of 3
    • Remove the metallic 12.2mm JIS #1 screw. This will need additional hands in reverse to hold the disk reader steady.
    • Remove the yellow tape on the reader strip and gently remove the disc reader without touching the laser reader.
    Ask FixBot
  17. Sega Saturn Motherboard Replacement, Motherboard: step 17, image 1 of 3 Sega Saturn Motherboard Replacement, Motherboard: step 17, image 2 of 3 Sega Saturn Motherboard Replacement, Motherboard: step 17, image 3 of 3
    • Remove the four metallic 15.5mm JIS#1 screws from the Motherboard Frame.
    • Remove the four metallic 13.6mm JIS#1 screws from the Motherboard Frame.
    • Remove the metallic 12.3mm JIS#1 screw from the Motherboard Frame.
    Ask FixBot
  18. Sega Saturn Motherboard Replacement: step 18, image 1 of 3 Sega Saturn Motherboard Replacement: step 18, image 2 of 3 Sega Saturn Motherboard Replacement: step 18, image 3 of 3
    • Lift the motherboard frame out carefully because of the delicate parts on the motherboard.
    • You do not need to remove the plastic Power LED Reflector. If it does pop out, don't worry, it can be pushed back into its socket. It may require rotation to fit the case when closed.
    Ask FixBot
  19. Sega Saturn Motherboard Replacement: step 19, image 1 of 3 Sega Saturn Motherboard Replacement: step 19, image 2 of 3 Sega Saturn Motherboard Replacement: step 19, image 3 of 3
    • Lift the motherboard away from the controller sockets in the front of the device while keeping your hands on the edges of the board
    • Once the back of the motherboard is above the back of the case, lift backwards to pull the cables out of their sockets to free the motherboard.
    Ask FixBot
Jan Ulloa
630 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2019 Member of USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
3 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 163
All Time: 9,189
