Sega Saturn Case Replacement
    1. Sega Saturn Case Replacement, Battery: step 1, image 1 of 2 Sega Saturn Case Replacement, Battery: step 1, image 2 of 2
      • Press on the plastic lever on the back of the Sega Saturn to pop open the battery slot.
      Ask FixBot
    2. Sega Saturn Case Replacement: step 2, image 1 of 3 Sega Saturn Case Replacement: step 2, image 2 of 3 Sega Saturn Case Replacement: step 2, image 3 of 3
      • Push up the edge of the battery with the iFixit opening tool to get the battery out of its socket.
      Ask FixBot
    3. Sega Saturn Case Replacement: step 3, image 1 of 3 Sega Saturn Case Replacement: step 3, image 2 of 3 Sega Saturn Case Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use the ESD safe tweezers to pull the battery out of its slot.
      Ask FixBot
    1. Sega Saturn Case Replacement, Case: step 4, image 1 of 3 Sega Saturn Case Replacement, Case: step 4, image 2 of 3 Sega Saturn Case Replacement, Case: step 4, image 3 of 3
      • Remove the five black 13.5mm JIS#1 screws on the bottom of the device. One might be hidden by a sticker.
      Ask FixBot
    2. Sega Saturn Case Replacement: step 5, image 1 of 3 Sega Saturn Case Replacement: step 5, image 2 of 3 Sega Saturn Case Replacement: step 5, image 3 of 3
      • Flip the device over so it rests right side up.
      • Lift gently across the seam of the Sega Saturn. If parts get stuck, a light shake or prying with the iFixit opening tool should free it up. Do not use any brute force, as this can damage the case so it doesn't close again.
      Ask FixBot
Jan Ulloa
630 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2019 Member of USF Tampa, Team S1-G6, Leahy Fall 2019
USFT-LEAHY-F19S1G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 110
All Time: 5,183
