Up to 20% off select tools
Sega Genesis Power LED Replacement
Views: 22K
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
191
All Time:
22,389
Comments: 5
5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This repair guide wil give a walk through on how to replace the power LED in a Sega Genesis.
    1. Sega Genesis Power LED Replacement, Outer Case: step 1, image 1 of 1
      • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
      Ask FixBot
    2. Sega Genesis Power LED Replacement: step 2, image 1 of 1
      • Flip the Sega Genesis upright.
      Ask FixBot
    3. Sega Genesis Power LED Replacement: step 3, image 1 of 1
      • Gently lift the top casing.
      • Note: the case will be connected to the main board by LED wires.
      Ask FixBot
    4. Sega Genesis Power LED Replacement: step 4, image 1 of 1
      • Bend out the LED leads into vertical positions.
      Ask FixBot
    5. Sega Genesis Power LED Replacement: step 5, image 1 of 1
      • Slide the LED wire apparatus off the lead pins.
      • Note: observe which color wire corresponds with which length of pin.
      Ask FixBot
    6. Sega Genesis Power LED Replacement: step 6, image 1 of 1
      • Separate the main board from the outer case.
      Ask FixBot
    1. Sega Genesis Power LED Replacement, Power LED: step 7, image 1 of 1
      • Remove plastic "Power / On" cover by pushing tabs together.
      Ask FixBot
    2. Sega Genesis Power LED Replacement: step 8, image 1 of 1
      • Pull "Power / On" cover away from the console cover.
      Ask FixBot
    3. Sega Genesis Power LED Replacement: step 9, image 1 of 1
      • From the outside of the top cover, remove LED.
      Ask FixBot
    4. Sega Genesis Power LED Replacement: step 10, image 1 of 1
      Ask FixBot
    5. Sega Genesis Power LED Replacement: step 11, image 1 of 1
      • Re-insert "Power / On" cover until it clicks into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When installing the new LED, make sure that the longer of the two legs is inserted into the side of the connector with the red wire.
5 other people completed this guide.
Author
with
Anthony Porchia
455 Reputation
1 Guide authored
Cal Poly, Team 3-29, Regan Fall 2010 Member of Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Members
60 Guides authored
5 Guide Comments
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Brandon - Reply Share
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
PIero Bogani - Reply Share
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
snoopydaturd - Reply Share
Hey snoopy don't give up hope I made a video on how to fix your problem check out this video
https://youtu.be/HJPyhfy56a0
thebigtoe_98 - Reply Share
Does anybody have any advice on how to replace the LED cable from the motherboard? Guess which numpty snapped it at the solder point.
Dboins - Reply Share
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 191
All Time: 22,389
