Up to 20% off select tools
Sega Genesis Outer Case Replacement
Views: 24K
View statistics:
Past 24 Hours:
4
Past 7 Days:
46
Past 30 Days:
202
All Time:
23,941
Comments: 0
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This repair guide will take you through all the steps for removing the outer case of the Sega Genesis.
    1. Sega Genesis Outer Case Replacement, Outer Case: step 1, image 1 of 1
      • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
      Ask FixBot
    2. Sega Genesis Outer Case Replacement: step 2, image 1 of 1
      • Flip the Sega Genesis upright.
      Ask FixBot
    3. Sega Genesis Outer Case Replacement: step 3, image 1 of 1
      • Gently lift the top casing.
      • Note: the case will be connected to the main board by LED wires.
      Ask FixBot
    4. Sega Genesis Outer Case Replacement: step 4, image 1 of 1
      • Bend out the LED leads into vertical positions.
      Ask FixBot
    5. Sega Genesis Outer Case Replacement: step 5, image 1 of 1
      • Slide the LED wire apparatus off the lead pins.
      • Note: observe which color wire corresponds with which length of pin.
      Ask FixBot
    6. Sega Genesis Outer Case Replacement: step 6, image 1 of 1
      • Separate the main board from the outer case.
      Ask FixBot
17 other people completed this guide.
Author
with
Erik Bjornstrom
852 Reputation
3 Guides authored
Cal Poly, Team 3-29, Regan Fall 2010 Member of Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 202
All Time: 23,941
