Sega Genesis Motherboard Replacement
    1. Sega Genesis Motherboard Replacement, Outer Case: step 1, image 1 of 1
      • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
      Ask FixBot
    2. Sega Genesis Motherboard Replacement: step 2, image 1 of 1
      • Flip the Sega Genesis upright.
      Ask FixBot
    3. Sega Genesis Motherboard Replacement: step 3, image 1 of 1
      • Gently lift the top casing.
      • Note: the case will be connected to the main board by LED wires.
      Ask FixBot
    4. Sega Genesis Motherboard Replacement: step 4, image 1 of 1
      • Bend out the LED leads into vertical positions.
      Ask FixBot
    5. Sega Genesis Motherboard Replacement: step 5, image 1 of 1
      • Slide the LED wire apparatus off the lead pins.
      • Note: observe which color wire corresponds with which length of pin.
      Ask FixBot
    6. Sega Genesis Motherboard Replacement: step 6, image 1 of 1
      • Separate the main board from the outer case.
      Ask FixBot
    1. Sega Genesis Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • Remove single black screw from the outside of the bottom cover, using a Philips screwdriver.
      Ask FixBot
    2. Sega Genesis Motherboard Replacement: step 8, image 1 of 1
      • Using a Philips screwdriver, remove 11 screws securing silver casing.
      Ask FixBot
    3. Sega Genesis Motherboard Replacement: step 9, image 1 of 1
      • Remove silver case.
      Ask FixBot
    4. Sega Genesis Motherboard Replacement: step 10, image 1 of 1
      • Remove single golden screw on motherboard using Philips screwdriver.
      • Note: Push headphone jack to the side.
      Ask FixBot
    5. Sega Genesis Motherboard Replacement: step 11, image 1 of 1
      • Remove two black screws on the left and right sides of the cartridge slot.
      Ask FixBot
    6. Sega Genesis Motherboard Replacement: step 12, image 1 of 1
      • Remove motherboard.
      Ask FixBot
    7. Sega Genesis Motherboard Replacement: step 13, image 1 of 1
      • Re-install new motherboard.
      Ask FixBot
14 other people completed this guide.
Erik Bjornstrom
852 Reputation
3 Guides authored
Cal Poly, Team 3-29, Regan Fall 2010 Member of Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Members
60 Guides authored
1 Guide Comment
When i played game 10 or 5 min
My consol hanged
And so need rest
What problem ?
Mojtaba Nikoei - Reply Share
Past 24 Hours: 8
Past 7 Days: 43
Past 30 Days: 259
All Time: 39,552
