This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide will help you disassemble your Sega Genesis II 6-button controller. You will need a Phillips #00 screwdriver to complete this guide.
This specific model was released in 1992/93, at the same time as the Sega Genesis II. However, it is also compatible with the Sega Genesis I.
Flip the controller upside down.
Using a Phillips #00 screwdriver, remove the five screws holding the controller back cover in place.
Remove the motherboard from the controller body, after releasing the rubber part that holds the cable in the controller body.
Remove the contact pads.
Then remove the 8 plastic buttons.
In order to disassemble the directional cross, it is necessary to levergentlypreferably with a plastic Spudger, under the 4 retaining tabs.
Then, push in the central hole with a fine tool (here a screwdriver), in order to undo the assembly.
Follow these steps in reverse order to reassemble your device.
Special thanks to these translators:
100%
tayola is helping us fix the world! Want to contribute?
Start translating ›
