This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Sega Genesis 6 button controller
    1. Sega Genesis 6 button controller, Disassembling the handle: step 1, image 1 of 1
      • Flip the controller upside down.
      • Using a Phillips #00 screwdriver, remove the five screws holding the controller back cover in place.
      Ask FixBot
    2. Sega Genesis 6 button controller: step 2, image 1 of 1
      • Then remove the back cover of the controller, which gives you access to the motherboard of the controller.
      • Carefully put back the 5 screws from step 1 as well as the back cover of the controller
      Ask FixBot
    3. Sega Genesis 6 button controller, Disassembling the motherboard: step 3, image 1 of 2 Sega Genesis 6 button controller, Disassembling the motherboard: step 3, image 2 of 2
      • Remove the motherboard from the controller body, after releasing the rubber part that holds the cable in the controller body
      • This gives you access to the button contact pads
      Ask FixBot
    4. Sega Genesis 6 button controller, Dismantling the buttons: step 4, image 1 of 1
      • Remove the contact pads
      • Then remove the 8 plastic buttons
      Ask FixBot
    5. Sega Genesis 6 button controller, Dismantling the Directional Pad: step 5, image 1 of 3 Sega Genesis 6 button controller, Dismantling the Directional Pad: step 5, image 2 of 3 Sega Genesis 6 button controller, Dismantling the Directional Pad: step 5, image 3 of 3
      • In order to disassemble the directional cross, it is necessary to levergentlypreferably with a plastic Spudger, under the 4 retaining tabs.
      • Then, push in the central hole with a fine tool (here a screwdriver), in order to undo the assembly
      • For reassembly, be careful to put the corrector in front of the slot of the outer part!
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Special thanks to these translators:
fr en
38%
tayola is helping us fix the world! Want to contribute?
Start translating ›
Thierry Benitez
331 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 87
All Time: 2,731
