Sega Game Gear TV Tuner Disassembly
    1. Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: step 1, image 1 of 2 Sega Game Gear TV Tuner Disassembly, Remove Housing Screws: step 1, image 2 of 2
      • Remove PH1 screw and lift up on the antenna to remove it
      • This can be done with a PH0 screwdriver but I prefer not to risk stripping the screw
      • Remove 4 PH0 screws
      • Remove 2 3.8mm gamebit screws
      • Lift rear tuner shell away from unit
      Ask FixBot
    2. Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: step 2, image 1 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: step 2, image 2 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tint Wheel: step 2, image 3 of 3
      • Before we can remove the motherboard the tint wheel needs to be removed
      • A peek on the inside reveals 2 small retaining clips. Simply apply some pressure on the clips with a needle nose tweezer
      • When reinstalling the tint wheel simply align the retaining clips with the holes and press back into place
      • Remove the motherboard from the unit
      Ask FixBot
    3. Sega Game Gear TV Tuner Disassembly, Remove PCBs: step 3, image 1 of 2 Sega Game Gear TV Tuner Disassembly, Remove PCBs: step 3, image 2 of 2
      • When removing the front shell be careful not to lose the frequency switch button located on top of the device
      • If it makes your repair easier you can separate the two PCBs by gently pulling the ribbon out of its connector. This is a friction fit cable
      Ask FixBot
    4. Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: step 4, image 1 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: step 4, image 2 of 3 Sega Game Gear TV Tuner Disassembly, Remove Tuning Dial Assembly: step 4, image 3 of 3
      • Flip the PCBs over with the back side facing you.
      • Remove 1 PH0 screw
      • Flip the board over again and gently pull the tuning dial assembly out of the pin header socket
      Ask FixBot
4 other people completed this guide.
Navy Vet 2015
8,357 Reputation
15 Guides authored
3 Guide Comments
does anybody know what the ribbon cables pinout is? I would love to know, so I can hook up some video-in to the tv tuner board, since my good guess is, that the upper part is just transporting or converting the signal it gets from its receiver to a mere video-in signal with LandR audio, since you can also hook up video-in to the tv tuner on the jack. and my other wild guess is, that the board the actual receiver is hooked up to splits up the signal into 8-bit chunks the game gear itself can understand. Please feel free to correct me and give more info, i NEED the pinout, since i got no tools at home to check what the ribbon cable actually is cooking.
patoschkapeter - Reply Share
A small washer fell out of mine when I was taking it apart. Any idea where it goes?
Kyle Mitchell - Reply Share
If it's very thin and small circumference it goes between the antenna and swivel. There may be 2 of them.
Navy Vet 2015 - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 112
All Time: 5,211
