Sega Game Gear Screen Replacement
    1. Sega Game Gear Screen Replacement, Battery: step 1, image 1 of 1
      • Place your device upside down and locate the two battery compartments.
      Ask FixBot
    2. Sega Game Gear Screen Replacement: step 2, image 1 of 1
      • Press on the tabs at the bottom of the battery covers then lift up to remove.
      • Remove batteries if they are present.
      Ask FixBot
    1. Sega Game Gear Screen Replacement, Case: step 3, image 1 of 1
      • Remove the following screws:
      • Six Phillips screws
      • One 4.5 mm Gamebit screw
      Ask FixBot
    2. Sega Game Gear Screen Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to take all other screws out.
      Ask FixBot
    3. Sega Game Gear Screen Replacement: step 5, image 1 of 2 Sega Game Gear Screen Replacement: step 5, image 2 of 2
      • Gently open the case by unfolding it over the top of the Sega Game Gear.
      • Do not pull the back of the case away, as cables are connected between both sides.
      Ask FixBot
    4. Sega Game Gear Screen Replacement: step 6, image 1 of 3 Sega Game Gear Screen Replacement: step 6, image 2 of 3 Sega Game Gear Screen Replacement: step 6, image 3 of 3
      • Carefully unplug the 2 white-tipped connectors on the top cover.
      Ask FixBot
    1. Sega Game Gear Screen Replacement, Screen: step 7, image 1 of 1
      • Unscrew all the marked screws.
      Ask FixBot
    2. Sega Game Gear Screen Replacement: step 8, image 1 of 1
      • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
      Ask FixBot
    3. Sega Game Gear Screen Replacement: step 9, image 1 of 1
      • Place the board onto a flat surface.
      • Small plastic buttons may fall off during this process, save them in a container or a place where they could be found later on.
      Ask FixBot
    4. Sega Game Gear Screen Replacement: step 10, image 1 of 1
      • Unscrew the marked screws.
      • Flip the board, having its back facing up.
      • Hold onto the screen in the back, as it will flip open if not held onto.
      Ask FixBot
    5. Sega Game Gear Screen Replacement: step 11, image 1 of 2 Sega Game Gear Screen Replacement: step 11, image 2 of 2
      • Make sure the screen is towards the bottom, as indicated in the second picture.
      Ask FixBot
    6. Sega Game Gear Screen Replacement: step 12, image 1 of 2 Sega Game Gear Screen Replacement: step 12, image 2 of 2
      • Gently open the screen up.
      • The screen will not come out all the way since it is glued onto the top side.
      Ask FixBot
15 other people completed this guide.
Lauren Thurston
506 Reputation
3 Guides authored
Cal Poly, Team 28-33, Regan Spring 2010 Member of Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Members
72 Guides authored
12 Guide Comments
any one know where to get a new display that wont bleed me dry?
theikester - Reply Share
Due to the nature a Game Gear screen attaches, a ribbon directly soldered to the mainboard, replacing it requires a soldering iron and some fairly advanced technique.
This guide, titled “Sega Game Gear Screen Replacement”, only takes us to the point you remove the ribbon. There is much work left.
Anthony Bessel - Reply Share
so, uh, is there a more comprehensive version somewhere?
rollin - Reply Share
Thank you. I was wondering why they left this out.
Jamie O'Connell - Reply Share
Does the screen get fixed at the end?
Caedmon O’Brien - Reply Share
Past 24 Hours: 7
Past 7 Days: 76
Past 30 Days: 387
All Time: 74,539
